s tsb technical service bulletin
TSB's (Technical Service Bulletin's)
[Image: 9nd4_zpsea5fce57.jpg]
Here is a list of the TSB's (Technical Service Bulletin's).
Please note these are in TSB's number order.
2469 2-22-11 Glued driveshaft - Missing service instruction.pdf
2473 3-19-13 Engine A-Z13DT-C-E-H-J-R - Smoke and or sizzling noise from cylinder head.pdf
2494 2-14-11 Universal Hand free Phone (UHP) - Only charging function.pdf
2495 1-21-14 Engine A17-20-DTC-H-J-L-R - Increased idle speed.pdf
2570 2-12-10 Opel Eye Switch in Steering Wheel Cruise Control Switch - Without Function.pdf
2580 7-29-11 Front seat - Noise, perceptible movement of seat cushion.pdf
2583 3-23-10 Engine Z-A17DTx, Engine Control Unit - Hang up during programming with MDI.pdf
2595 10-19-10 Radio - CD does not eject.pdf
2599 1-14-10 VIN-label - Wrong colour coding for Olympic White and Waterworld Blue.pdf
2601 2-11-10 Engine A20DTx - Delayed engine speed decrease when shifting.pdf
2604 11-22-10 Engine A-Z16-18XER - Booming Noise between 2500 - 3500 rpm.pdf
2610 11-13-12 Engine A16-18-XER-LET SVS illumates - P0597 stored.pdf
2615 5-3-10 Engine A17DTR-J - Cruise Control does not work according to specification.pdf
2621 1-10-12 Display - Flickering.pdf
2625 11-12-10 Transmission F17+ - Shift Lever Fine Adjustment.pdf
2626 4-4-12 Engine A20DTx - Glow plug with pressure sensor related failure codes.pdf
2630 5-6-10 Active headrest - Triggered.pdf
2634 3-23-10 Driver Information Centre - Code 174 displayed.pdf
2636 4-7-10 Transmission GF6 - Noise from transmission during cornering.pdf
2638 10-27-14 #14-E-2638 F40 - Knocking noise at load reversal in all gears especially in 2nd and 3rd gear.pdf
2642 4-14-10 Engine A16LET - Surge noise between 1500 and 2000 1-min.pdf
2646 5-4-10 Rear End Carrier (Flex-Fix) - Does not engage in extended position.pdf
2650 5-17-11 Cruise control, clutch apply sensor - Malfunction.pdf
2652 5-21-10 Engine - Does not start.pdf
2656 7-15-10 Inner Sill Trim, Clutch pedal - Distance too low.pdf
2664 8-2-12 Coolant level - Display shows Coolant level low.pdf
2672 12-7-11 Engine A20DTx Engine Management System - Oil Pressure too low, shut off engine appears in instrument cluster.pdf
2676 7-28-10 Instrument Panel Fuse Box - IEC Bus Bar Incorrect Numbering.pdf
2678 3-13-12 Engine Z-A17DTx - Lack of power and DPF glogged, SVS on, DTC P242F and-or P2003 might be locked.pdf
2683 4-29-11 Brake apply sensor - Brake light flickering.pdf
2684 9-7-12 Engine A20DTx - Check DPF or SVS on, DTC P2453 (5A) in ECU set..pdf
2685 9-22-11 Engine A14NEL-T - DIC message AC off due to high temp, SVS on, TC P0128 set.pdf
2686 9-1-10 Interior - Streaks on different covers.pdf
2691 9-2-10 Engine A16LET - Jerking during gear change.pdf
2696 12-7-10 UHP (Low-High-Embedded) - Phone book sorting, delay of recieved calls.pdf
2700 9-27-13 Clutch Pedal - Noisy.pdf
2714 11-8-10 Engine A17DTJ-R - Stalls during drive off.pdf
2718 11-1-11 ABS-ESP Telltale Illuminates - Several Trouble Codes are set.pdf
2723 11-24-10 Manual transmission M20-M32 and F40 - Reverse gear blocked or impossible to engage reverse gear.pdf
2724 1-10-11 Paint FRESKO BLUE - Paint deviation between Front- Rear Bumper and Body.pdf
2734 12-10-10 Engine A20DTx, Turbocharger - Loss of power, trouble code P003A, P0299 and P2263 set.pdf
2735 4-4-11 Radio CD400, CDC400 - USB Connector no Function.pdf
2745 1-19-11 Battery, beauty cover - Missing.pdf
2756 2-16-11 Rear Quater Window Panel - Design Change.pdf
2757 4-29-11 Radio DVD800 CD500 - Can not be switched on.pdf
2764 11-16-11 Heating Ventilation - Water Ingress.pdf
2769 12-14-11 Radio CD500 or DVD800 - Missing languages within config menu.pdf
2770 3-2-11 UHP - Bluetooth-PIN cannot be changed.pdf
2771 5-6-11 Pre Fuse Box (UEC) - Loose connection, P037E and or P0383(00) set.pdf
More will be added later.
top work rusty very useful
The TSB for the F40 gearbox, mine does this but how would I word it to vauxhall so I don't get fobbed off?
You'd have to book it in and they will do "their diag"
If they say no fault tell them its the same issue as the TSB number 14-E-2638.
Or tell them when booking in you know there is a TSB out for the issue you have.
Ok thanks buddy, I'll give them a ring and book it in.
