Trade Count:
( 0)
Threads: 0
Thanks Received: 0 in 0 posts
Thanks Given: 0
0
Car: Insignia 2.0cdti
Sex: Male
Total Feedback: 0
Can someone tell me..I updated NAVI 600 to 900. Now, i would like to try change theme but I don't know which version I'm using now ?
I read somewhere that I can't put V208 if my is V200 .How I can know which version is my ?
Trade Count:
( 0)
Threads: 0
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
12:th-Nov-2019, 13:29:13
(This post was last modified: 12:th-Nov-2019, 14:03:56 by Acika.)
Oh ,now I worry about this .. I "updated" yesterday and now, like I said, I have 3d map options and more things,
but the system software is still same like before .. What do I need to do now?
I am so so so so STUPID !!!
Everything is good ...
but when I tried to import POI the NAVI said that is the newer version of software on USB.
Now I was tried with firmware from disk, just to be sure, and I saw that is the same version of software (new one, from disk)
I'm apologize because of my crazy messages today.
Trade Count:
( 0)
Threads: 0
Thanks Given: 0
0
Car: Vauxhall zafira
Sex: Undisclosed
Total Feedback: 0
Hi, guys,
I want ask, just now I got zafira with navi600 and find it can be update to 900.
Is there any new files for that or stay same files is little longer when was this work so just suggest if files and Process still same or change it
Trade Count:
( 0)
Threads: 0
Thanks Given: 0
0
Car: Astra J 2014
Sex: Male
Total Feedback: 0
I know I'm a bit late to the party but I tried doing this and after second installation(2nd time USB) it stayed navi 600. No options for 3d maps, no red theme, no nothing? What do I do now?
Trade Count:
( 0)
Threads: 1
Thanks Given: 0
0
Car: insignia
Sex: Male
Total Feedback: 0
Hi I have a navi 600 I'm looking for a way to get Bluetooth music playing functionality, will this upgrade/install drivers to make it do that?
It already supports phone calls through Bluetooth and I was wondering if this would add that functionality ?
Zebb
Trade Count:
( 4)
Threads: 359
Thanks Received: 8 in 8 posts
Thanks Given: 1
73
Sex: Male
Total Feedback: 0
(1:st-Jul-2020, 10:55:22)zebb.guy@hotmail.co.uk Wrote: Hi I have a navi 600 I'm looking for a way to get Bluetooth music playing functionality, will this upgrade/install drivers to make it do that?
Zebb
No only way to get audio streaming is to get a navi950 (there are some 650 which have it but rare).
Trade Count:
( 0)
Threads: 0
Thanks Given: 0
0
Car: Insignia
Sex: Other
Total Feedback: 0
I bought latest map update 2019/2020 and apply it into my unit NAVI 600 already. After that I found this great forum and this thread about upgrading my navi unit from 600 to 900. Before I started I read posts in this thread and it made me confused. Some members said that if you use newer map update with this upgrade it may brick my unit.
1. So I ask you now if I have already inserted and applied new version of maps 2019/2020 into my unit does it means I shouldnt try this upgrade because of risk to brick my unit?
2. What if I insert my old maps 2015/2016 into my unit and downgrade maps will I than be able to apply this upgrade?
3. Steps described in first post are a little bit confusing. When screen "programing flash failed" appear instructions say this "IT WILL THEN ASK YOU TO REBOOT. REMOVE THE USB STICK. YOU WILL NOW BE IN THE BOOTLOADER 5 SCREEN" ----> does this means I need to to remove USB STICK before pressing countinue or I remove USB stick after clicking COUNTINUE and before entering into BOOTMODE. Will this procedure of rebooting automatically performed by my navigation or I have to turn it ON? Will I enter BOOTLOADER automatically by the system when I click CONTINUE?
4. Instructions then say this "INSTALL THE CDR DISK IN BOOTLOADER 5 MODE AND REBOOT BY PRESSING THE EJECT BUTTON". Why I need to press EJECT button? I thought when I insert CD (with fix files) it will be recognized automatically and proceed with installation. I think when I press EJECT button it will eject CD? THIS STEP description is really confusing. Please help me with this part "WHEN YOU HAVE THE CORRECTLY COPIED THE DISC JUST INSERT IT INTO THE NAVI
IT WILL THEN FLASH OFF THE INFO FROM THE DISC TO THE NAV
THIS TAKES TIME DO NOT INTERFERE TILL THIS IS COMPLETED
WHEN IT IS DONE CONFIRM INSTALL AND WAIT TILL THIS IS COMPLETED."
5. This step says: "INSERT THE NAV600 SD MAP CARD BACK INTO THE CAR
AND START THE SAT NAV IT WILL THEN REBOOT
AND FOLLOW THE ON SCREEN INSTRUCTIONS
IT WILL THEN UPDATE THE SD MAP UPDATES FROM THE SD NAVI 600 MAPS CARD
AFTER THAT HAS COMPLETED THEN TURN THE NAV ON AND OFF."
Do I need to manually do REBOOT pressing knob "OFF" "ON" or system will automatically reboots after this step?
6. "AND THEN REINSERT THE USB STICK
WHEN THE INSTALL SCREEN COMES ON THE NAVI REMOVE THE NAVI 600 SD MAP CARD
LEAVING THE USB STICK IN PLACE
AND THEN FOLLOW THE ON SCREEN INSTRUCTIONS AND THIS TIME IT WILL INSTALL TILL 100% CORRECTLY.
WHEN COMPLETED REMOVE THE USB STICK AND REBOOT THE NAVI
THEN INSTALL THE NAVI 600 SD MAP CARD AND TURN THE NAVI OFF AND ON
THE UPDATE IS NOW COMPLETE."
When system installation is completed this time to 100% correctly will it promt me to restasrt/reboot system by pressing COUNTINUE BUTTON? Do I need to remove usb stick before pressing countinue button? Or I need to manually reboot by pressing big knob button? Do I need to turn off navi and then insert SD and than TURN on the navi OR system will automatically reboots and than I insert SD and turn system off/on.
Pls help me I know I am confused but understand me I dont want to finish with bricked devicde because I dont have money to replace another. Thank you
Trade Count:
( 0)
Threads: 0
Thanks Given: 0
0
Car: Opel Astra J
Sex: Male
Total Feedback: 0
2:nd-Aug-2020, 12:21:29
Hi guys (and girls if any), new on the forum and new on this mod for our radios.
Last night updated my Navi 600 of my Astra J to the navi 900 firmware, it looks like it all worked fine.
Now i have a few doubts...
3D map shows a ugly gold bar on top, is that normal or that's the place for the sky? made the update at night, didn't check if the same bar apears on the day mode.
About theme update, atm i'm now at v181, if i update using a v208 theme file, does that upgrade my navi to v208?
Found these 3 themes on the insignia-driver.uk forum, can i use them safelly?
Post #4.
( https://insignia-drivers.uk/forum/insign...post133398)
Any way to see what they look like without flashing on after another? Specially the exinfinity one.
Last question, just bought this ( https://www.ebay.com/itm/VAUXHALL-OPEL-C...Swsvhe0Vpw) on ebay, what happens if i use the card on v181 and on v208? Will it work on both versions and will it upgrade something on the navi?
Thanks in advance for the replys guys.
Trade Count:
( 0)
Threads: 0
Thanks Given: 0
0
Car: insignia
Sex: Male
Total Feedback: 0
Can any help can't get of the reboot
Trade Count:
( 0)
Threads: 0
Thanks Given: 0
0
Car: Opel Astra J 2013
Sex: Male
Total Feedback: 0
I did everything the tutorial said after the step where it says software update complete , restarting navigation or something like that it restarts and just changes the language the themes are the same and there is no 3d maps or some maps options for head up 2D or north up 2D, it's the same version from before can someone help?
Trade Count:
( 0)
Threads: 0
Thanks Given: 0
0
Car: Astra
Sex: Undisclosed
Total Feedback: 0
I am new to this and I would like to update my Navi 600 to Navi 900
Does this also work with an SD card, since my Astra works with an SD card and not with a USB stick
Regards,
Marcel
Trade Count:
( 0)
Threads: 0
Thanks Given: 0
0
Car: Astra
Sex: Undisclosed
Total Feedback: 0
I have an Opel Astra Sport Tourer 1.4 2012
Where do I find the USB stick slot because I can't find it
I only see the SD card slot
Or do I just use any usb slot?
Will the Navi 900 in the end installed on the SD card?
Regards,
Marcel
Trade Count:
( 0)
Threads: 0
Thanks Given: 0
0
Car: Astra
Sex: Undisclosed
Total Feedback: 0
Is the Dutch language also available on this upgrade?
Regards,
Marcel
Trade Count:
( 0)
Threads: 0
Thanks Given: 0
0
Car: Astra
Sex: Undisclosed
Total Feedback: 0
My final question?
On my SD card BENELUX has been pre installed on a very very small SD card
Will this interfere with the update described here?
Regards,
Marcel
Trade Count:
( 0)
Threads: 0
Thanks Given: 0
0
Car: Astra
Sex: Undisclosed
Total Feedback: 0
I am a bit confused
When I unzip the migrate_600to900 zip file, there is no iso file, but a dnl folder with (as far as I can tell) the same files as on the navi_600_900_rus_fix (which is an iso)
So what do I copy to the USB stick? The dnl folder incl the subfolders?
Regards,
Marcel
Trade Count:
( 0)
Threads: 0
Thanks Given: 0
0
Car: Astra
Sex: Undisclosed
Total Feedback: 0
Before I want to try this, Ihave a question:
Does this still work in 2021?
Regards,
Marcel
Trade Count:
( 0)
Threads: 0
Thanks Given: 0
0
Car: Insignia
Sex: Undisclosed
Total Feedback: 0
Hello
Started the upgrade and getting the same message of please insert downloadable medium, I cant seem to get the CD-R to write the boot change so the unit will read the disk
Any advice
Trade Count:
( 0)
Threads: 0
Thanks Given: 0
0
Car: Mokka 2012
Sex: Male
Total Feedback: 0
Amazing pal, I just installed on Mokka 2012 1.6 petrol, the CD was enough to complete it!! thank you very much for this update
