view camera rear
Rear view camera
Hi I have just fitted an Astra K rea rview camera to my Cascada and connected it to a Navi600 unit. But  I am struggling to find a reverse feed for it, I had thought I had found one but alas it didn't work so to test the wiring I fed this wire directly to a live feed from the battery which got the camera to work when I put it in reverse so I know all the rest of the wiring is correct.
Does anybody know where I can get a reverse feed from as I have had a look at the back of the wiring on the rear light and all the harness colours are black and the actual wires going to the bulbs are wired in together in parallel with a black and a brown wire so it looks like the canbus must send the signal down the wires to the correct bulb (i'm guessing) as the rear lights and stop lights are OEM LED units.
Pick it up behind the trim lh side in the boot. green/white
  Factory Reverse Camera, Astra j/GTC, insignia tucpal 34 40,640 30:th-Aug-2025, 20:00:16
Last Post: obsidian
  fit reversing camera on astra j gtc tzr608 23 25,081 14:th-Mar-2021, 20:35:53
Last Post: _Mita
  How To Modify Rear Door Card From Car With Elec Windows To Fit Car With Window Winder Jetcolour 5 11,468 24:th-May-2020, 10:19:26
  AUTO DIM ANTI DAZZLE REAR VIEW MIRROR retro fit tucpal 72 82,685 4:th-Aug-2019, 18:26:52
Last Post: KKEVANSKK
  Astra J Sport tourer and OEM rear view camera saarits 47 56,801 26:th-Mar-2019, 23:38:23
Last Post: tzr608
  Retrofit Rear Power point 5 door Astra J Ballinlea 3 15,239 20:th-Mar-2019, 18:13:44
4 User(s) read this thread:
husky (4:th-Apr-2026, 06:51:00), obsidian (31:st-Aug-2025, 13:14:57), pieppopieppo (11:th-May-2025, 06:46:49), owenc1 (23:rd-Nov-2025, 23:29:48)
