needs priming? fuel pump
Fuel pump needs priming?
I recently had my fuel tank replaced due to a hole in the pipe s, since it’s been replaced I need to prime my fuel pump every time I start the car or it will just turn over for what seems like ages!
Is there any way of fixing this??
Should be self priming, I'd check fuel filter condition also. When I did my fuel filter I'd took a few turns before springing into life.
I also had to have a new fuel tank as had a hole, I have an issue now though of tank not registering level correctly. I may have a look in the summer but I tend to fill up on halfway. You could also check they haven't kinked a pipe.
I had a new filter fitted also, it starts fine with stop/start just when it’s been stood for a while I have to turn the key and wait for pump to prime before I start it
Sounds to me like the fuel is bleeding back to the tank, don't know if they have one way valve or not but the pipe should remain full
  VAUXHALL ASTRA 1.7 CDTI FUEL SENDER UNIT 13272601- FUEL ERRATIC GUAGE BELWO HALF TAN caretaker 3 4,249 21:st-Oct-2024, 18:22:15
  Threaded Mode Diesel Fuel guage erratic low fuel and then half tank caretaker 1 4,845 30:th-Dec-2022, 17:32:20
Sad Astra 1.7 CDTI fuel quality problem klajdi 0 4,045 10:th-Sep-2020, 12:10:05
Last Post: klajdi
  ESP service message, erratic fuel range figures on trip computer mpotsb 2 6,080 7:th-Sep-2020, 12:04:29
Last Post: mpotsb
  Fuel Shutoff Valve NuttySqurill 1 3,509 12:th-Aug-2020, 07:58:08
  1.7cdti drinking fuel Hazard10 2 5,005 9:th-Jan-2020, 22:13:15
Last Post: Peckalz
  New Fuel filter. Wont start SALMHAGE 1 4,275 18:th-Dec-2019, 23:24:29
Last Post: SALMHAGE
  How to change Astra j fuel flap mechanism? Amazingusername 2 5,788 11:th-Oct-2019, 12:56:58
Last Post: Amazingusername
  Fuel consumption - 1.3 CDTI mw2299 3 6,319 19:th-Oct-2017, 10:53:43
  2.0cdti ECU update for DPF causing poor fuel & loss of performace Rusty2009 17 26,128 23:rd-May-2017, 07:00:23
