m32 gearbox whine
Gearbox whine m32
Probably been pushing it for too long, but 2017 1.4t gtc has developed a whine, starting July last year at around 30k. Increasly getting louder. 41k now.
Reading that the gearbox is the notorious M32 and is common issue. Generally the whine starts above 20mph and get louder with speed, no movement in gear stick, can be a bit stiff when cold.
Any recommendations to check this is the gearbox whining and not something else? Also any recommendations for a garage that understands the M32 issues around Manchester?
I can't advise on a garage but would advise popping along to gearbox specialist.
  2.0 CDTi Auto Gearbox Oil Change Dennis S 0 3,827 13:th-Aug-2021, 14:29:25
Last Post: Dennis S
Wink F40 gearbox oil amount Wak1969 10 12,183 13:th-Nov-2020, 16:28:55
Last Post: eatmybogbrush
  2014 Astra 2.0L 165 HP F40 gearbox quantity of oil?? Kpal11 3 6,851 12:th-Jan-2020, 16:38:41
Last Post: Kpal11
  Gearbox Oil drain plug? shabba 13 14,830 10:th-Jan-2018, 11:59:11
Last Post: stigeye
  Gearbox Oil Change? doug143 0 4,797 14:th-Jan-2016, 21:05:49
Last Post: doug143
