j range keyfob astra
Astra J Keyfob range
hi guys
My keyfob and spare normal key has very short range to unlock/lock vehicle. i must be within 2m from car to work.
Already replaced both battery's
is there anything that i can try in order to fix this issue?
thanks
There is nothing in terms of an aerial there could be other interference causing the issue.
I know on the Meriva there was an aerial used to extend the range but on the Astra they used a different set of component's where by you can't.
Could be a blessing in disguise, a couple of times I found the car unlocked in the morning (know I locked it previous night), when I accidentally pressed the key in my pocket in the house, once with front windows half rolled down.
I now put the key in safe place in house when I get home.
Sent from my BV6800Pro using Tapatalk
  VAUXHALL ASTRA 1.7 CDTI FUEL SENDER UNIT 13272601- FUEL ERRATIC GUAGE BELWO HALF TAN caretaker 3 490 21:st-Oct-2024, 18:22:15
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 3,735 12:th-Sep-2021, 15:24:05
  Vxr bumper on 5 door Astra j Sh4rk2007 10 9,990 6:th-Jun-2021, 18:25:04
Last Post: jeniferbitcoin71
  New Battery for Astra J 2013 reg 1.7 diesel Galway11 6 5,030 13:th-May-2021, 11:38:55
  Astra J 1.4T Exhaust help sammpennington 1 4,937 12:th-May-2021, 14:29:50
Last Post: azajus
  Astra j gtc modifications BillyBryan 2 2,407 9:th-May-2021, 17:15:36
Last Post: Spaghetti
  Astra J Fault code reader suggestions Euroshopper 1 2,532 22:nd-Feb-2021, 08:50:12
  Astra j bonnet won't open help Paul in sheppy 2 2,772 17:th-Feb-2021, 13:13:46
Last Post: Paul in sheppy
  Astra J GTC PDC bracket milozic 5 3,318 2:nd-Feb-2021, 09:39:35
  Astra J Rear Bench Seat Clip. MrScottyMan 1 5,017 24:th-Jan-2021, 14:44:22
