box auto gear
Auto gear box
Hi all my daughter has a 2010 astra j 1.6 auto the problem is it wont change out of first gear , it will go into park but when you put it in drive it stays in 1st and does not change up, in reverse its ok, the engine warning light has come on and when we had the aa out 2 codes came up saying input speed sensor malfunction -p0716 the other code said input speed sensor no signal p0717, has anyone had the same problem or no of it happining to anyone, your hepl would be appreciated.
Sound's like it could be the sensor at fault or a broken wire.
Would be best getting a good auto spark out to look at it.
it's worth checking the wiring to the sensor for damage or breaks
otherwise it needs some further diagnostics
this might help (or not) depending on gearbox model
https://workshop-manuals.com/vauxhall/as..._or_p07c0/
