fault charge start
Start/Charge fault
Recently I got my J back on the road after it had been stood for a year without being started much.
The car had been running fairly well for the first week or so so I decided I was gonna treat it to a full service, replace the thermostat (had the "service vehicle soon" message for some time), coil pack, get some new floor mats and take care of the minor advisories on the MOT.
For a week I noticed that the car was starting to get very sluggish turning over, but it always fired up. Eventually one day in a petrol station it failed to start so I was lucky enough to get a jump start to get going. Once home the starting issue turned into nothing more than a click on startup.
Jump starting wouldn't work, I could only start it with a push.
I ordered a new Varta Blue battery and it was delivered next day, but despite the new battery being fully charged the car would still only click and not turn over.
I took advice from a few people and also did a lot of research to diagnose the problem, and everything pointed to a faulty starter motor.
I booked it into a local garage and today they tell me that there is no charge going into the system, the tests showed there was no charge coming from the alternator.
(On the way to the garage I got a new message, "Service battery charging system" and the battery light stayed lit)
So anyway I'm told I need a new alternator, is this likely to be an expensive fix?
This year I plan to trade the car in so I'm not really inclined to spend a fortune on it, so should I go for an OEM quality part or pay the extra and get genuine?
Apologies for the wall of text, and thanks for any replies.
If you are planning on trading in I would go pattern part have a look on GSF they have 56% off until the 18th using code GSF56
(16:th-Feb-2018, 10:23:43)Rusty2009 Wrote: If you are planning on trading in I would go pattern part have a look on GSF they have 56% off until the 18th using code GSF56
Thanks Rusty I'll check them out and see if buying the part and having it fitted compares well to the quotes I have (for both supply and fitting) had so far. Best quote came in locally at £290 which seemed pretty fair to me. Would be great if I can get it cheaper still  Thumbs
  Uneven idle and hunting on initial start up Jpbroad1970 2 5,789 24:th-Aug-2021, 09:34:41
  Astra J Fault code reader suggestions Euroshopper 1 5,325 22:nd-Feb-2021, 08:50:12
  Intermittent start, stalls after clock sweep no throttle response Jump to Latest Brendonm9477 5 8,644 5:th-Jan-2021, 13:55:10
  Retrofitting stop/start system momoomar 3 5,171 23:rd-Apr-2020, 13:44:22
  astra j 2.0 start up cornwall37 2 5,370 10:th-Apr-2020, 13:47:56
Last Post: Kiel0777
  New Fuel filter. Wont start SALMHAGE 1 4,437 18:th-Dec-2019, 23:24:29
Last Post: SALMHAGE
  Start up issue... only once daveloz12 4 7,413 22:nd-Mar-2019, 10:02:26
Last Post: daveloz12
  Opcom Fault Codes murasakizo 3 5,721 4:th-Mar-2019, 12:03:03
  What would cause stop/start to not work? Vx-Mad-G 12 26,949 1:st-Jan-2019, 10:15:22
Thumbs Down Astra J, turns but will not start randilio1 6 8,567 2:nd-Dec-2018, 19:01:23
