gtc astra auto knob replacement gear
Astra GTC auto gear knob replacement
Hi Iv got a 2014 Astra GTC Auto, I’m after some advice, Iv spoken to Vauxhall themselves and they want £300 for a replacement gear knob.
The rubber on my gear knob has worn and split, also in the recent snow my car got stuck and while flicking from reverse to drive to rock the car out of a ditch the button on the back of the gear knob has snapped.
Does anyone know where I can get a replacement for a more reasonable price, and how to fit the replacement.
Many thanks
Jay
I'm also interested in a solution for this as mine is also in need of change
looking at pictures of removed auto gear levers it looks like it would require the gear cables to be disconnected, electrical plugs disconnecting and then unbolting the gear lever assembly from the floor. There is most likely a set up required to refit the cables.
You would need to remove the centre console to access the assembly.
Having said that if you only wanted to replace the actual gear knob it probably just unclips from the metal shaft, I know on the manual cars it only takes a couple of seconds to remove the gear knob.
(3:rd-Jan-2018, 12:58:13)vocky Wrote: looking at pictures of removed auto gear levers it looks like it would require the gear cables to be disconnected, electrical plugs disconnecting and then unbolting the gear lever assembly from the floor. There is most likely a set up required to refit the cables.
Yeah it is only the actual gear knob I want to remove. At the weekend I will have a proper look and see if there is anything under the gaitor. It looks like on solid unit. Vauxhall have said that it requires the whole gear shift assembly which also has its own ECU in hence the expensive price.
Just thought some pics may help [Image: 1960476318e5e4e2ab6a0be91e21c02a.jpg][Image: 6a970368541e2ce0ce30de88fd850946.jpg]
A quick google suggests the knob is a separate item, and thus should be able to change easily.
https://www.ebay.co.uk/i/282280744247?ch...801&crdt=0
EDIT, a further google found a how2 on YouTube for an Insignia. I can't see changing the Astra-J knob being any different.
https://www.youtube.com/watch?v=bNDy8QS5E44&vl=en-GB
Further EDIT
It isn't by the looks of it.
https://www.youtube.com/watch?v=w9VKncS5YaI
looking at Vauxhall parts catalogue the knob comes with boot and surround
depending on trim level about £240.00 plus vat
You don't need the boot and surround though. See my earlier post. You can remove the knob from the stick and just replace the knob. The boot is just held to the knob with a cable tie.
Plenty of good 2nd hand ones around, without resorting to spend £240 + vat.
Ok cheers all. Will get it done this weekend.
The knob itself does come of quite easily. I followed those instructions on the YouTube link I previously posted.
Granted, I didn't remove the surround or gator, but when I put gearstick into neutral and pressed in the reverse lock catch, I simply gave the gear knob a slight twist left and right - along with pulling upwards at the same time and the knob came off the gearstick with little effort. It also clicked back into place easily too.
I'm sure once you remove the surround and gator, you'll have no problems replacing it.
Hello all,
It seems I have the exact same issue as the original poster.
I've identified ;
https://www.ebay.co.uk/itm/Automatic-Gea...Sw2uheqqga
or
https://www.ebay.co.uk/itm/VAUXHALL-OPEL...Sw4CFYvbpv
As a replacement, and I've watched a youtube video or two on how to replace them.
Is this a path I should go down or should I just bite the bullet and pay the 300 pound quoted price? I'm not a practical guy at all so don't want to mess this up. I'm also assuming Astra J is Astra GTC? Mine is a 64 plate, white GTC Auto etc.
(4:th-Jan-2018, 12:44:17)Big Dave2 Wrote: A quick google suggests the knob is a separate item, and thus should be able to change easily.
Further EDIT
Holy moly, is that last video legit? Can I just pull it out like that and replace it?
Further EDIT
Almost. You'll also need to detach the gearknob from the leather/vinyl gaiter.
I never changed mine in the end as it only had a small split in the rubber. I did take it off though to repair the split with superglue.
I unclipped the surround at the base of the gaiter using a metal ruler, making sure I was careful not to mark the plsatic, and then proceeded to remove the gearknob as per the YouTube clip.
Once removed, fold the gaiter over the top of the gearknob and you'll see a cable tie. Cut this and the gearknob can be separated from the gaiter. Fitting is the reverse of removal as they say.
Further EDIT
Thanks.
I just bought -https://www.ebay.co.uk/itm/Automatic-Gea...2749.l2649
Hoping it fits and is compatable.. I think it is.. My car is an Astra GTC 1.4 Turbo 64 plate... But now looking at the ebay listing I'm not sure whether this will be okay for a GTC?? God damnit...
  Astra J 2014 1.6 petrol, dashboard noise help Steve1982 0 1,108 9:th-Sep-2025, 08:39:49
  Astra J 2014. Electric static noise under dash Steve1982 0 1,033 8:th-Sep-2025, 21:22:49
  2010 Astra J - Cooling Fan issue Madal101_uk 3 4,132 19:th-Dec-2024, 22:04:08
Last Post: Madal101_uk
  High pitched noise (Astra OPC J) maximame 0 7,066 24:th-Mar-2021, 08:34:13
Last Post: maximame
  Gear Knob issue (Automatic 2014 Astra GTC) DC23 1 8,239 22:nd-Feb-2021, 08:08:37
  Astra J. Can a tyre valve be replaced without replacing the TPMS? benawhile 2 7,938 5:th-Aug-2020, 12:33:14
Last Post: benawhile
  Astra J SRI 13 Plate - Radiator Fan Gavin1506 2 7,067 11:th-Jul-2020, 22:08:04
Last Post: Gavin1506
  Astra J 1.6 CDTi increased fuel consumption _Mita 2 11,888 1:st-Mar-2020, 22:27:38
Last Post: _Mita
  Astra ST 1,6 CDTi, error code P0181 claymansvk 1 5,868 20:th-Feb-2020, 19:32:31
  shock absorber noises astra j blacknik 1 7,475 10:th-Feb-2020, 08:34:15
N0madd_builds (29:th-Dec-2025, 23:52:48)
