light back faulty
Faulty back light
Hi folks
I've got a faulty back light on drivers side if I tap the lens it will come on but won't come on till I tap the lens any idea it's really bugging me I've tried taking the bulb out and putting it back in but still no joy
Try changing the bulb. The filament might have become detached, and tapping it temporarily reattaches it again.
Also, try cleaning the bulb contacts.
Thanks Dave I'll try it tomorrow when I got it in the garage
(16:th-Aug-2017, 19:03:18)Jon3sy Wrote: Hi folks
hi mate I had the same problem on a kia, I was forever changing bulbs,so what I did was to switch lights and ingnition off and with a small screwdriver scraped the contacts in the bulb holder, the pins may look good but give a try, plus a new bulb will help.
since then I had no problems.
good luck chap.............
I've just had the same problem on the passenger side!! Replaced the bulb, seems to be sorted!!
  Coolant light coming on when coolant is full (new sensor and no leaks) baffling me! Brasseyebaby 3 8,111 2:nd-Feb-2021, 21:12:47
  DPF REGEN LIGHT Starie 113 147,889 19:th-Apr-2020, 21:00:20
Last Post: Multiskilled
  Astra Issues – Faulty thermostat? dmort 1 7,106 15:th-Apr-2020, 12:30:52
Shocked Spanner Light illuminated with engine off Wwood1991 2 5,959 11:th-Feb-2020, 13:01:57
  Rear Light Replacement (Need Advice) A.ROD 2 7,512 17:th-Dec-2018, 19:17:48
Last Post: A.ROD
  Help engine light Mspencer 12 17,103 18:th-Mar-2018, 17:17:36
Last Post: Mspencer
  Putting the J back on the road CraigSRi 7 10,973 5:th-Jan-2018, 10:47:35
Last Post: rlievens
  No wiring for the interior boot light marcus01 5 9,232 20:th-Dec-2017, 16:48:23
Last Post: rlievens
  Rear fog light bulb ID jl47 0 5,651 15:th-Dec-2017, 15:24:34
Last Post: jl47
  Airbag light always on? Ssss 12 15,419 5:th-Oct-2017, 10:50:28
