recalibration sensor afl level
AFL level sensor recalibration
Rusty is there any chance you could have a look on your MDI program to see if theres anything for recalibration of the AFL leveling sensors
There is something mate I remember reading it, I'll have I a look tomorrow.
Here you are Baz,
Vauxhall Workshop Manuals > Astra J > Diagnostic Navigation > Programming and Setup > Repair Instructions > Headlamp Control Module Programming and Setup
You want the bit right down the bottom although always good to know the other info as well.
Thanks mate is this something you can do
I've not done it before but should be straight forward enough, VX will charge me though which is roughly £10 by the time you factor in there handling charge and the bank / credit conversion charge as being a 13 plate you could only do it online.
Your welcome to play with it yourself mate.
  Fuels Temperature sensor Nuko-san 8 14,033 4:th-May-2019, 19:03:50
Last Post: StevieRay
  LED’s for up level display sparkyscfc74 10 15,489 11:th-Mar-2018, 20:11:51
  Sensor Box Window Tint sheppy1 1 6,433 29:th-Jul-2016, 16:10:25
  Third break light/High level break light VK91 3 7,851 3:rd-Jan-2016, 22:18:03
Last Post: cornishtaz
  Light sensor warning! Alienbv 9 9,825 12:th-Mar-2015, 15:30:35
  Remove the sensor casing on the windscreen JohnL 3 9,105 9:th-Apr-2014, 18:17:59
