door j lighting astra
Astra J door Lighting
I have Astra J enjoy model 2016 and i tried to connect door light
i connect lamp light at passenger door at terminal 1(black) and 2 (yellow) and it working fine with the dimmer without any problems
and also i connect at driver side at terminals 1 (black) and 4 (red) but i found it go light on always and it not on dimming control, so please i need to know the best connection and solution.
The RED wire is your problem as that's just power.
https://www.vxoc.org.uk/forum/Thread-How...oor-lights
ok i checked the red wire and it continues volt
and i don't know where i can connect the positive wire of LED.
i tried all terminals :(
(9:th-Feb-2017, 12:38:12)Rusty2009 Wrote: The RED wire is your problem as that's just power.
i have this terminal socket
[Image: pgilk75vn]
http://postimg.org/image/pgilk75vn/
Do you have rear electric windows also?
yes all windows
Ok I'll look the plug up tomorrow.
waiting you
(9:th-Feb-2017, 20:39:16)ahmedkashaf Wrote: waiting you
Please see attached it should be Pin 4.
.pdf   Astra-J S79D Window switch - Driver.pdf (Size: 33.07 KB / Downloads: 46)
but pin 4 it continuous volt and it red wire.
  Astra GTC Horn issue ed-b 5 3,391 14:th-Oct-2020, 08:42:36
  Astra J GTC retroffiting PDC milozic 2 3,429 22:nd-Sep-2019, 18:56:19
Last Post: milozic
LindsayMerrick (18:th-Feb-2024, 07:02:00), dave67 (29:th-Mar-2024, 10:34:37)
