s drl
DRL'S
Does anyone know how to solve only 1 DRL bulb not working on an Astra GTC VXR? I've upgraded to LED bulbs and they've been great since September, however when checking yesterday, I noticed only 1 is working, since then I've bought new bulbs and swapped the failed one out but still no change? If anyone could point me in the right direction that would be great??
I had this issue on my 5-door I left the car lock for a few hours and then it was fine.
Failing that you could try pulling the negative off the battery for 30+mins (will allow all systems to shut down).
If that doesn't work I would suggest you could have another faulty bulb or there could be a wiring issue, what you could do is swap the working bulb over for testing as you know it works.
it must be the bulbs there ether fitted the wrong way around or there are faulty bulbs
but also check your tail lights are working as there are also linked to the drl
Might need no error load resitors m8
(25:th-Apr-2016, 20:07:30)kyle-astra-j Wrote: Might need no error load resitors m8
Not needed on a GTC
One of mine (right hand side) seems be jammed in somehow. I pulled the wires and it didn't move and obviously I'm reluctant to to put too much strain on the wires so as they don't get damaged. .
Any ideas. .
Heard there's Mod's about. .
Did you squeeze the 2 tabs while pulling?
Good point Rusty . .
(23:rd-Dec-2016, 07:50:37)Simon Templar Wrote: Good point Rusty . .
I always squeeze whilst I pull   Lol
