test pedal help
Pedal test help
Hi, can anyone help me to diagnose this fault code please?
Any help will be much appreciated. I've had nothing but problems with his car from the day I bought it!!
https://youtu.be/-jJdUpfw5Rg
have you had the fault code read any local garage or dealer will be able to do it
Not yet, outworking the garage hours at the moment before I go on holiday so was hoping someone on here could help
i can say it needs looking at but guessing just wont help you out
if you can get the actual fault code then we can tell you what it is
The J doesn't have a pedal test.
(21:st-Sep-2016, 16:15:03)Jordanclark666 Wrote: Hi, can anyone help me to diagnose this fault code please?
You need a decent diagnostic test done on your J.
Engine size? Symptoms your having?
Oops! I'm a bit late on this one.
  Astra J manual – pedal box gone? pretty expensive! Mr Writer 5 17,194 9:th-Sep-2021, 14:27:28
Last Post: Gav-Astra
  Brake pedal creep Kippermcflipper 5 9,582 12:th-May-2017, 21:08:11
Last Post: Kippermcflipper
  Compression test dimkozi 1 5,194 26:th-Apr-2017, 07:02:48
