a questions few noobie
A few noobie questions
Evening.... I've tried the search feature but had no luck....
I have a 12 plate gtc 2.0 cdti ....
1) is the front upper grill easy to take off ?
2) are the little shark fin things on the side of the roof spoiler easy to take off ?
3) is the rear badge easy to take off?
I'm wanting to do a few touches of my own
Any help I would appreciate
Thanks in advance
James
The grill is a bumper off job.
The other bits not sure on.
@Shorty S91 he's the best person to ask as he's done these things on his GTC
Thanks for the replies
Evening buddy sorry I didn't get back to you sooner. The bumper needs to come off completely if you want to remove the grill. The rear badge will come off easy enough with a hair dryer and a plastic card. I haven't removed the shark fin however I believe all you need to do is remove the rubber seal abound the boot and some of the trims and the headliner will drop enough for you to loosen the bolt for the ariel. I am off tomorrow so ill go take some pics and make a tutorial to remove the front bumper if there isn't already one Wink
Hi shorty and thnx for the replies..... I meant the big round Vauxhall badge / boot release to take off .... Is it just clipped on do you know ?
Cheers James
(19:th-Aug-2016, 21:45:49)Shorty S91 Wrote: Evening buddy sorry I didn't get back to you sooner. The bumper needs to come off completely if you want to remove the grill. The rear badge will come off easy enough with a hair dryer and a plastic card. I haven't removed the shark fin however I believe all you need to do is remove the rubber seal abound the boot and some of the trims and the headliner will drop enough for you to loosen the bolt for the ariel. I am off tomorrow so ill go take some pics and make a tutorial to remove the front bumper if there isn't already one Wink
Regarding the shark fins ..... My mistake referring to them as that .... I was talking about the little black plastic things attached to the roof spoiler at each side
Cheers james
Large Vx badge is stuck on BUT it is stuck on a round piece of body coloured metal that's the boot release... its obviously not smooth under it.
(20:th-Aug-2016, 08:38:40)J1ODYA Wrote: Large Vx badge is stuck on BUT it is stuck on a round piece of body coloured metal that's the boot release... its obviously not smooth under it.
Cheers for that
I've seen someone do it but wish I had a pic... basically only remove if you're putting something exactly the same size back on lol
I think he's referring to these that you did on your GTC...
[Image: 1320d26c72d87958209896e20af45ed2.png]
(20:th-Aug-2016, 09:23:54)J1ODYA Wrote: I've seen someone do it but wish I had a pic... basically only remove if you're putting something exactly the same size back on lol
The original badge will be going back on :0)
Thanks james
(20:th-Aug-2016, 10:16:01)stigeye Wrote: [quote='Shorty S91' pid='38322' dateline='1471639549']
Yes those are the things I'm talking about :0)
Cheers James
Managed to get the spoiler fins off and had a play 5d Carbon wrapping them
they should look good
(21:st-Aug-2016, 19:38:58)tucpal Wrote: they should look good
I think you are right :0). I get the wingmirrors done aswell to tie it all in
Cheers james
  New Owner - Few Questions pr0xibus 5 6,248 25:th-Feb-2023, 20:15:36
Last Post: pr0xibus
Question Three GTC VXR questions neilll 3 4,736 14:th-Aug-2021, 21:33:37
Last Post: neilll
  New owner of Sports Tourer.. a few questions. Marc_81 8 9,083 16:th-Oct-2018, 22:58:05
  Few Questions JJ00 1 4,644 23:rd-Feb-2017, 18:57:04
  1.6T 180bhp questions raimon 25 30,917 27:th-Aug-2016, 16:33:07
Last Post: srea064
  A few questions about my Astra gregj 5 12,284 11:th-Jul-2016, 22:40:24
Last Post: gregj
  Many much Questions GOKIWI 3 6,930 3:rd-Jun-2016, 14:16:25
