vibrates lever gear
Gear lever vibrates
Good morning,
I'm new on the forum and this is my first post.I got a astra J 1.7 cdti 125hp from 2011. When i'm driving and shift in to 4th gear (especially there) the gear lever starts to vibrate (sometimes hard). I asked a machanic and he said it's propably the gear box giving away because it's common that they brake down. I made this post to get a second opinion.
[Image: db401d045c929d7e7bd03e597025ec27.jpg] my car
Verstuurd vanaf mijn D5803 met Tapatalk
This is a link so you can hear what i mean. (sound in the background is my daughter paying a game  )
Is the car under warranty?
I'm sure I've seen a TSB about this.
Will need to look tho.
When bought the car it came with 2 years waranty and after it must be extended but it’s not been done. Thanks mate
(9:th-Feb-2016, 13:31:32)Regi Wrote: When bought the car it came with 2 years waranty and after it must be extended but it’s not been done. Thanks mate @Rusty2009
I've been through the TSB and there is nothing. I know I've seen something about it somewhere but I can't for the life of me find it.
Are you getting any grinding noises?
No ain't getting that.Just see and hear it vibrating. The sound is like you pronounce this, drrrrrrrrr drrrrrrrrr () @Rusty2009
Is it definitely the gear lever? Does it stop when you put your hand on it?
The sound stops but i can still feel it like vibrating.@bhalay207
@bhalay207
it may well be the gear linkage remove the gear stick cover and check for excessive play in the two linkages
then open the bonnet and again check the two linkages on the gear box
but i would say in your case to get the car looked at it may not be as bad as you think
No it's definitely the gear box, i went on a dutch forum friday and read about it. Alot of people with similar problem and conclusion was the gearbox is up for revision. @tucpal
  Can't get in gear - clutch problem? klargon 0 5,182 9:th-Dec-2017, 16:21:11
Last Post: klargon
  Gear stick ( broke ? ) Daz21 9 10,936 6:th-Dec-2017, 23:31:24
Last Post: nosteb90
  Damaged gear knob trim chrisb2511 12 13,149 26:th-Jun-2016, 11:54:28
Last Post: M1C VX
  Retrofit gear stick surround ambient light sotoskon 14 16,916 14:th-Feb-2015, 15:27:52
  LED GEAR KNOB tucpal 5 8,763 7:th-Feb-2015, 23:43:07
gemini6791 (17:th-Oct-2025, 09:13:55)
