I have an 11 plate Astra 2.0cdti sri. I have been having problems with a puddle appearing on the passenger side floor. There are no other wet areas of the car, and it doesn't happen everytime it rains. I saw a youtube video of an older vectra that had the same issue and it was caused by a drainage cup? under the front screen getting clogged up. I think i might have the same problem as it doesn't happen everytime it rains. I had a look around that general area but as i know next to nothing about cars i have no idea what I'm looking for. Has anyone had the same issue?
Tags |
passenger floor astra 0cdti 2 sri puddle |
Astra 2.0cdti sri puddle passenger floor
24:th-Sep-2015, 15:36:39
Check pollen filter if wet replace pollen filter remove blower motor check if wet this was an old problem with water trailing down the wiper arms inside the scuttle panel the GM fix is to tie a zip tie around the drivers side wiper arm in the scuttle panel about an inch up near the sticker on the wiper arm motor have not heard of this for a good few years now
24:th-Sep-2015, 18:42:07
What tucpal said mate, usually any water in the passenger side of cars is down to the pollen filter getting clogged
24:th-Sep-2015, 22:52:46
There is a TSB for this I'll dig it out tomorrow.
25:th-Sep-2015, 08:55:03
Thanks for the reply guys
25:th-Sep-2015, 09:05:42
25:th-Sep-2015, 12:30:51
my car did this when i first got it they did fix it
and they did do the above how to and add a zip tie i have had no problems since |
