midlevel vehicle the messages display on
Vehicle Messages on the Midlevel Display
[Image: vx.o.c.jpeg]
The Vehicle messages are displayed as code number.
2. No radio remote control detected, depress clutch pedal for a restart
3. Engine coolant level low
4. Air conditioning off
5. Steering wheel is locked
6. Depress brake pedal to release electrical parking brake
7. Turn steering wheel, switch ignition off and then on
9. Turn steering wheel, start engine again
12. Vehicle overloaded
13. Compressor overheated
15. Centre high-mounted brake light failure
16. Brake light failure
17. Headlight levelling malfunction
18. Left low beam failure
19. Rear fog light failure
20. Right low beam failure
21. Left sidelight failure
22. Right sidelight failure
23. Reversing light failure
24. Number plate light failure
25. Left front turn signal failure
26. Left rear turn signal failure
27. Right front turn signal failure
28. Right rear turn signal failure
29. Check trailer brake light
30. Check trailer reversing light
31. Check left trailer turn signal
32. Check right trailer turn signal
33. Check trailer rear fog light
34. Check trailer rear light
35. Replace battery in radio remote control
48. Clean side blind zone alert system
49. Lane departure warning unavailable
53. Tighten gas cap
54. Water in diesel fuel filter
55. Diesel particle filter is full
56. Tyre pressure imbalance on front axle
57. Tyre pressure imbalance on rear axle
58. Tyres without TPMS sensors detected
59. Open and then close driver window
60. Open and then close front passenger window
61. Open and then close rear left window
62. Open and then close rear right window
65. Theft attempted
66. Service theft alarm system
67. Service steering wheel lock
68. Service power steering
69. Service suspension system
70. Service level control system
71. Service rear axle
74. Service AFL
75. Service air conditioning
76. Service side blind zone alert system
77. Service lane departure warning
79. Top up engine oil
81. Service transmission
82. Change engine oil soon
83. Service adaptive cruise control
84. Engine power is reduced
94. Shift to park before exiting
95. Service airbag
128. Bonnet open
134. Park assist fault, clean bumper
136. Service parking assist
145. Check washer fluid level
174. Low battery
258. Park assist off
3 User(s) read this thread:
Jordan_Sparkes (7:th-Mar-2025, 01:53:35), BryanRIX (18:th-Feb-2025, 15:28:57), ShawnFeP (8:th-Feb-2025, 13:52:14)
