Vehicle Messages on the Midlevel Display - Printable Version +- VXOC Astra-J/GTC (https://vxoc.org.uk/forum) +-- Forum: Astra-J/GTC Section (https://vxoc.org.uk/forum/forumdisplay.php?fid=5) +--- Forum: Astra-J/GTC Technical (https://vxoc.org.uk/forum/forumdisplay.php?fid=20) +---- Forum: Vauxhall General (https://vxoc.org.uk/forum/forumdisplay.php?fid=27) +---- Thread: Vehicle Messages on the Midlevel Display (/showthread.php?tid=1691) |
Vehicle Messages on the Midlevel Display - Rusty2009 - 20:th-Jul-2015 Vehicle Messages on the Midlevel Display The Vehicle messages are displayed as code number. 2. No radio remote control detected, depress clutch pedal for a restart 3. Engine coolant level low 4. Air conditioning off 5. Steering wheel is locked 6. Depress brake pedal to release electrical parking brake 7. Turn steering wheel, switch ignition off and then on 9. Turn steering wheel, start engine again 12. Vehicle overloaded 13. Compressor overheated 15. Centre high-mounted brake light failure 16. Brake light failure 17. Headlight levelling malfunction 18. Left low beam failure 19. Rear fog light failure 20. Right low beam failure 21. Left sidelight failure 22. Right sidelight failure 23. Reversing light failure 24. Number plate light failure 25. Left front turn signal failure 26. Left rear turn signal failure 27. Right front turn signal failure 28. Right rear turn signal failure 29. Check trailer brake light 30. Check trailer reversing light 31. Check left trailer turn signal 32. Check right trailer turn signal 33. Check trailer rear fog light 34. Check trailer rear light 35. Replace battery in radio remote control 48. Clean side blind zone alert system 49. Lane departure warning unavailable 53. Tighten gas cap 54. Water in diesel fuel filter 55. Diesel particle filter is full 56. Tyre pressure imbalance on front axle 57. Tyre pressure imbalance on rear axle 58. Tyres without TPMS sensors detected 59. Open and then close driver window 60. Open and then close front passenger window 61. Open and then close rear left window 62. Open and then close rear right window 65. Theft attempted 66. Service theft alarm system 67. Service steering wheel lock 68. Service power steering 69. Service suspension system 70. Service level control system 71. Service rear axle 74. Service AFL 75. Service air conditioning 76. Service side blind zone alert system 77. Service lane departure warning 79. Top up engine oil 81. Service transmission 82. Change engine oil soon 83. Service adaptive cruise control 84. Engine power is reduced 94. Shift to park before exiting 95. Service airbag 128. Bonnet open 134. Park assist fault, clean bumper 136. Service parking assist 145. Check washer fluid level 174. Low battery 258. Park assist off |
