to windows manual conversion electric
Manual to electric windows conversion
I bought 5 door leather interior for my car today (1.6 non-turbo 5 door Sri 10 plate) and fitter the rear seats with the arm rest, fitting the front seats and door cards tomorrow.
The rear door cards I got with the new interior are for electric windows but my car got manual windows. The new interior door cards got the templates on the back to drill a hole for the manual winders but is going to install the electric windows mechanisms in my car and plug them to the switches which come with the interior my question is will the wiring be on my wiring loom for the electric windows cause normally they are just taped to the wiring loom.
Any advice or ideas would be appreciated thanks 😃
you need to replace the front door looms (must be full electric) also I think there are some extra wires to the BCM etc you would also need new door loom for the rear doors plus then you need a VCI code.
If you would like me to upload the wiring diagrams I can.
Yes please if you could rusty. Do you know the part numbers also?
Wiring has been put a the tech section here
I can get part numbers mate do you have folding mirrors?
No mate no power folding mirrors
well If I get you the part number of loom which has that option if you decide to retrofit them later it will be easier for you?
will move this thread to retro fit section so can you carry on any info here for reference
13372683 Driver door
13372807 Passenger door
13284608 Rear door RH
13284607 Rear door LH
you need 4x looms 2x rear motors 2x rear switches 1x drivers switch
and a few wires changed on the BCM best look on ebay for second hand looms and mec,s
it will save you a fortune
I think the switch is different on the passenger side between full and front only
I have already got all the switches from a 5 door. All I need is the wiring looms and the mechanisms. The mechanisms I can buy from the same guy I had the switches from so that's not a problem it's just getting the looms with the part numbers rusty gave me or have a look on ebay. Then it's just having a look how it all goes together then a trip to vauxhall to get it coded up I guess
Has the chap not got the door looms mate?
Also a vauxhall dealer won't sort the VCI out, where are you based mate?
In based in South Wales
closest chap to you is ***** in Wolverhampton then mate, and it would be 2 trips unless you get there early on a week day and spend the day hanging around in the hope a VCI comes back the same day
Just make the rear door cards into manual, that's what me and [MENTION=19]Lewis6317[/MENTION] did, look standard now
Yeah they look good but i really want electric now :-/ but then it would mess with the module for the mirrors i believe
Lewis6317 Wrote:Yeah they look good but i really want electric now :-/ but then it would mess with the module for the mirrors i believe
No it won't mate, I'll sort that Saturday after requesting your VCI
May do the windows then, we see :-) lol
you would just add the wires to the loom for power fold again if they dont have them
but they most likely will have them already
(27:th-Oct-2014, 08:28:48)Rusty2009 Wrote: you need to replace the front door looms (must be full electric) also I think there are some extra wires to the BCM etc you would also need new door loom for the rear doors plus then you need a VCI code.
Hi, unsure if this thread is still active but has helped me with the rear electric window fitment to the Astra J SRI.
I have so far replaced all four door looms, fitted the rear window motors, panels and switches from an Elite.
The rear door body connections (X700 and X800) are missing the pins 1,10 and 15 which is not a problem,i can sort and also need to run a supply to the driver door switch pin 4 via X500 from the rear fuse box ,then re-programming.
Has any one got any details on the front door body connections (X500/X600)?
Thanks in advance.
  electrical rear windows Maniacu 12 12,024 19:th-Jul-2019, 12:27:57
Last Post: Maniacu
  Armrest with manual handbrake Grazza 16 22,333 3:rd-Sep-2014, 20:58:13
Last Post: Grazza
  open windows with the key tucpal 8 17,839 5:th-May-2014, 20:57:05
  auto windows tucpal 18 26,274 3:rd-Mar-2014, 08:07:24
3 User(s) read this thread:
jas7c5-2008 (30:th-Dec-2025, 16:32:38), AstraJ_FIN (14:th-May-2025, 14:52:39), N0madd_builds (3:rd-Dec-2025, 14:56:27)
