Fault Codes
[align=center][Image:
Fault Codes
Diagnostic Trouble Code (DTC) List - Vehicle
This master DTC list includes all applicable (B) DTCs in alphanumeric order with descriptors.
[TABLE=]
[TR]
[TD]
DTC [/TD]
[TD]
DTC Descriptor [/TD]
[TD]
Diagnostic Procedure [/TD]
[/TR]
[TR]
[TD]B0000[/TD]
[TD]Vehicle Speed Information Circuit Invalid Data.........Vehicle S
Rear Brake Light fault
I've got a 2011 sports tourer and my rear drivers side brake light has an error. If I remove the light and move the wires it works again. Looking to replace the wiring but it's all one unit at £56 just for that... anyone know of a common fault/fix for this? Could just change the whole light.
ajh1984 - Replies:
Heated seat fault - help!
First post asking for help, of course!!
I have a 2011 2.0cdti elite, with heated front seats as standard. For no reason at all they have stopped working, I get no light on the buttons when pressed. I've checked the fuse in the REC fuse 21 , that's fine, checked all the plugs under the seats, they are all tight and connected.
I'm at a loss of what to check next, any help would be much appreciated.
Al
Fault Code P24AC 1.7 CDTI
I have a 2011 Astra J 1.7 CDTI 96 kW A17DTF ecoflex and one Fault Code P24AC.
EGR Valve is fine. And also EGR Cooler Bypass Solenoid Valve.
[color=#333333][size=small][
Starie - Replies:
Fault code DTC P2458
Using op-com for the first time and found a fault code for what I believe to be the dpf anyone know why this could be showing ? Does it mean it the dpf needs to regenerate or because it's blocked or has a fault ?
GOKIWI - Replies:
Most Bizarre Fault Ever ?
So I have posted in the past about the dreadful performance of Doris, flat spots , poor acceleration etc. Well I have partially solved those problems.
J1ODYA - Replies:
My fault codes
Heater fault
Hi unsure is this is the right section to post this. But I've been noticing my heater isn't performing as good as it used to. Could be perfect today and the next day doesn't seem to be getting as hot. Any solutions to this? The cars a 1.7cdti
abs fault
hi all here we go again
i have a esp service now light on with fault code C0045-5a rh wheel speed sensor circuit- not plausible
i have change the wheel sensor as it was my first choice and still no luck as when you first pull away light goes out then hitting about 20mph light is back on which is correct so after some reading it seems it could be the encoding ring at fault which i feel is a poor design as its built into the wheel bearing
has anybody got any ideas as what next to look at
P0128 Fault code
Hello all and thanks for reading this.
Daughters GTC has P0128 fault code and A/C off due to high temp with fan running on full speed & temp gauge on dash not moving above 50 degrees.
New thermostat fitted - (old one was passing a little when cold)
Symptoms the same.
Looked at the service manual pages - should I now be looking at replacing another sensor in the radiator?
Many thanks.
