HOW TO: Replace Glove Box Bulb Without Removing Glovebox
So i thought id show you guys how to change the glove box bulb for a nice w5w 501 smd bulb, i used one with 12 smds.
Items needed:
Blunt knife of plastic lever
New bulb
So this firstly, how the light switch works, when the pin is extended the light comes on, when the pin is pushed in, the light goes off.
The first step is to use a blunt table knife or other tool to lift down the light from the rear a
VCI without installed part
Hey All [SMILING FACE WITH SMILING EYES]
Anyone know if it's possible to have a VCI code requested (officially) and programmed to the car without the part it's being installed to control being installed in the car?
Tech2-ing to a part without rest of car.. possible?
My trailer interface module is playing up a little, some times it detects the plug insterted and will do the bulb out warning on the dash, sometimes it dosent detect the plug is insterted,
i've 100% checked the switch in the socket is working, zero ohms when the plug is in, perfect connection when it's out (so the switch is open when plug is inserted)
i can't talk to the TIM with the tech 2 as it says hardware mismatch or no software available... this is because my chassis number isnt on
Astra J. Can a tyre valve be replaced without replacing the TPMS?
I have an Astra J hatchback, 2015 reg, I think it is “pre facelift” but not sure.
It has slow punctures on both off side wheels
My tyre garage (Formula 1 Autos) told me that air is leaking from between the valve body and the alloy wheel seat.
They say that if I can get hold of replacement valves they will replace them. They say that this will not involve disturbing the TPMS.
Are they correct?
Is the TPMS separate from the valve on this car? All I can find are combined TPMS and valve
