Astra GTC Hi-Per Strut lowering springs fitting
A quick how-to for fitting lowering springs to a GTC/VXR. These cars are fitted with the same suspension set-up as the Insignia VXR known as the Hi-Per Strut
Tools required
Trolley jack
Axle stand
E20 socket
T30, T40, T50 torx
8mm, 18mm, 19mm, 21mm, 24mm, 32mm sockets, through socket is best for the strut upper mount fixing
Locking wheel nut key
18mm, 21mm spanner
Hub puller
Ratchet
Breaker bar
Soft fac
Gas bonnet strut
I was doing some research on these, rusty got any further??
Custom Boot Strut Help
Hi All
I'm looking for a bit of help with regards to getting some custom boot struts made up to help push the boot lid open when I "pop" the boot using the key fob (this is for my 5 door astra).
I've looked on various sites but know nothing about any of the following questions they're asking...Can anyone assist and tell me what I would need to achieve the above?
Rod Diameter
Tube Diameter
Stroke Range
N Force Range
Panel (boot lid) weight
Cheers!
