squeaking clutch peddle
as there have been loads of reports
of the clutch peddle squeaking when you press it down
and this is a very simply fix
all you really need to fix this is
too add a good amount of grease
to the top of the clutch peddle
in the position marked in the picture
[Image: http://i179.photobucket.com/albums/w301/...5c1ae6.jpg]
it is a real tight space so i strongly recommend applying t
Squeaking from outside car
Ok so about a few months ago I have this really bad squeaking which sounded like it was coming from outside the car from drives side rear.
I have the discs and pads changed all round and never noticed the issue again, until the other day.
So after driving with the radio off, i can hear it again.
anybody got any idea what it could be?
Brakes questions - squeaking noise, rust, quality.
Hello guys,
Did a 60,000 KM service exactly one month ago.
I changed the front and rear pads + the rear discs, along with other things.
The car brakes fine, but there's a really annoying squeaking noise.
I called the garage and they said that there shouldn't be any squeaking noise at all, even if the discs and pads aren't original.
I'm gonna go there next week, but I wanted to check with you guys first.
1) Is squeaking normal with brand new discs and pads?
2) I have a lot of dust
Squeaking, whirring and grinding
I've had my J since mid-August. Haven't really had any issues until now. It's a 1.3 CDTI. I noticed a squeaking that was getting louder. I looked under the bonnet and it was one of the belts (not sure which) but it didn't quieten/get louder with acceleration. The squeaking has now died down and now I mainly hear a whirring from inside the car, as if the belt is struggling to go round. Just earlier on a short journey I heard three times, what I can only describe as a grinding sound, the same soun
