Water Noise Sloshing
Sigh! I thought I'd seen the end of the sloshing problems in my car but now I have a new one :(
I can hear what sounds like A LOT of water sloshing around in the boot area whenever I accelerate, break or turn. I used to hear this noise when I first got my car and it was the fuel in the tank because my tank didn't have baffles. Vauxhall eventually fitted some baffles and that was the end of that, never heard anything since then until today!
Got in my car for the first time in a f
Water sloshing sound
So I've noticed since I picked my Astra Tourer up at the weekend that I can hear a very occasional noise which sounds like water sloshing about if I pull away a bit quicker than usual. I've had a good google search and think it's probably inside the doors, now I've seen that to rectify this you can remove the rubber grommets at the bottom of the doors and give them a good clean. My question is, would it cause any problems if I left the grommets out altogether, or are they there for a reason? If
