Single driver side official mats
So my driver side mat is a bit worse for wear and I need a new one. It's 30 quid for a full official set on ebay which is good but I only need the driver side one! So does anyone have or know where I can get the driver side one only?
Single mass flywheel conversion for a 2010 2.0 CDTI Insignia
Hey guys!
My A20DTH160HP 2010 Insignia seems to be suffering from a worn out or damaged flywheel. It started with a small rattling noise and now, over the winter, the sound is louder than the aircon maxed out, the car vibrates at idle, it jutters whenever I shift gears or when I release the clutch pedal pulling off from a stand still. Engine braking also starts to sound like engine breaking.
Everyone seems to suspect that the flywheel is either worn out or damaged (the dampening springs
single din in astra j
hi guys just got my astra j 1.7 cdti eoflex s/s 130ps nice car.only problem is the cd400 what a load of crap
would like to put my pioneer dab in from my Astra h? is it possible,seen the facia adaptor but its double din
anyone done it,cheers
Single to dual horn upgrade retrofit
In this How-to, you'll see how you can replace your dinky single horn with a Dual horn.
Without removing the front bumper.
It seems Vauxhall decided that it was a good idea to put single horns in on a randomly select few Astra J's, no one knows why!
Cause it sounds like a clown horn on big cars like these!
So lets fix this!
Part number for the horn:
GM [size=small][font=Monaco, Consolas, Courier, monospace]13409130 "[size=small][font=Monaco, Consolas, Courier, monospace]HORN,ASSY.,400/500HZ"[
Rear Seat Belt Buckle-Drivers Rear-Single
Hi guys,
Im after a Rear Seat Belt Buckle please, I dont know if I have got the naming correct, but its basically what the rear seat belt plugs into.
I only need the single one, which is driver rear.
My car is a 2011 Elite, so dont know if its different on the other editions.
Many thanks.
Single Exit Exhaust swap to Twin Exhaust
Hello guys,
If you follow me on instagram @thewhiteastra you will see I put on the full VXR Aero bodykit on my GTC.
The GTC had a single exit exhaust on the passenger side.
The VXR exhaust has 2 built in exhaust tips passenger and drivers side.
I had to cut the tip off my single exhaust to get the bumper on as the VXR sits lower inc diffuser.
So basically the single exhaust pipe doesn't line up to the
