Faulty Boot Seams?
Good Morning (Just!)
I recall reading somewhere that early Astra's have a problem with the boot seams failing but I can't locate it.
Reason for asking is my Astra has water in the footwell which was partly due to the high level brake light, which is now changed.
However I am still getting water in the boot after rain and it appears to be coming out the seam on the boot floor at the back. I suspect this as when I wiped the water away I could see a drop of water re-emerging through the se
