Part number required
I need the number for the small clips that you screw on to hold the side skirts to the underneath of the car
feedback from those in the know required
Hi guys,
I'm planning on purchasing a retro fit bluetooth kit from Ray Smith for my astra. I also want a DAB add on, and I've seen another kit that I can install. I'm not sure that these two pieces if kit will run side by side without any issues.... not to mention the immense amount of wiring!
I emailed Ray Smith asking of they did an all in one alternative. He replied with this link:
[url]http://www.raysmith.co.uk/vehicle-specific/vauxhall-specific/vauxhall-astra-j-oem-replacement-navi
Part number required.
After the part number for the little black plastic clip that goes on the end of the seat runner.
Thanks John
Switcheed / Ignition positive feed required in boot area
Mr Newbie here. I am looking to install an accessory in the boot of my 2013 J - 1.6 Energy model. For this I need to locate a switched/ignition + feed.
This car does not have a rear fuse box, which make like a little more tricky.
Can anybody direct me to an appropriate feed please with a wire colour(s).
Many thanks in advance,
Ian
Astra 1.4t 140 2016 or newer Donor car Required
As the title says Superchips are looking for a Astra 1.4t 140 running euro 6 Ecu
[Image: http://i1079.photobucket.com/albums/w503...ug2w3.jpeg]
Urgent help required.
[align=center]Hi guys need advice. I have a gtc 2.0 diesel. Car was serviced a couple of weeks ago and got timing belt done too. Car has done 70000 miles and is a 2012. Anyway to cut a long story short, when I left garage warning came up service car soon, rang garage they said turn car off and start again and message should go away, which it did. Driving home from work today service car soon came on again and car immediately stalled. Nursed the car home but I had to go out again., service car so
Part Number Required
HI..I'm after a part number for a drivers side headlight...2013 2.0cdti sri. Thanks.
