Car pulling to the left
Anyone got any ideas? Tracking has been done and a second time to make sure the settings were correct which they were.
Brakes are not binding on the passenger side so I know it's not this.
Pulling to the left
So I had my tracking checked today and it was 11mm out to the left.
So they adjusted it, now it just pulls to the left all the time even on flat roads where it never use to pull.
Think I should take it back for a re-check?
Car pulling to the right
I have had the tracking done on my astra gtc and the garage says it drives straight. But it still pulling really bad to the left when the wheel is straight. They said the back wheels was out of line. They said they have done the best they can. Surely the car should drive straight if your wheel is straight.just wonder if any one has had the same problem. Car has 25k on the clock. Thanks for help.
Car pulling
I have a astra gtc 2l ctdi. It is Pulling to the right even after been tracked 3 times. It's had lesser tracking done and done at main dealer. Tire pressure are right. Same amount of ware of on both front wheels. Any help thanks.
