Program part off car
My trailer interface module won't program with the Tech2 due to my chassis number (A13DTE engine shouldnt have a towbar fitted it seems)
When it reads the VIN as part of programming it refuses... even if i use the VIN thats stored in the TIM, that's from a 1.7 engined meriva,
So i removed the GM-lan wire from the TIM, connected that to the tech2's obdii connector... pin 1 - gm-lan, pin 4 and 5 to earth, pin 16 to power,
i can talk to the TIM with the tech2 like this, read DTC's, oper
