gsisr - Replies:
Ignition problem?
This is what happens when I turn the key to start the car. I hope you can here it on video
http://youtu.be/jojejSidPWQ
klargon - Replies:
Can't get in gear - clutch problem?
Howdy! Got in the car last night and it would not go into gear (meant I had to run to the football instead!). Can stick it in gear when the engine isn't running. If I put it in gear before starting, I can't get out of that gear. I'm assuming this is a clutch problem, but I haven't noticed any indication of a problem developing. I drove it for about 80 miles the previous night. I have, however, been intermittently getting a Service ESP warning on the dash for the past week or two. It's obv
fuel temperature problem?
I have a fuel sensor with a negative value...how can I find witch sensor it is?
Injectors or SCV problem?
I have a problem with my 1.7 in the morning. I can feel it vibrate a bit to strong when the engine is cold. Everything is back to normal after 4 minutes. I haave read the injectors values and they are jumping around for 4 minutes until injectors will stabilize. Any in here that can read these values and tell me if the injectors are running properly?
[quote='kartush45' pid='52281' dateline='1583182564']
