How To use Draft posts
[align=center]This is how you use draft post.
Just the same making a new thread or post
1. input the title
2. Type your thread or post
3. Click the "save as draft post" button
4. Click the submit button.
To load your saved post you can click the button that says post with draft post and select the draft post you want you.
Re-input the title and edit away you can re save as draft post if you want or post it.
See video below (will be added once uploaded)
[video=youtube;lsI8_cOZ9Ak]https://ww
Attachments in posts blogs
Please note that members can only add 5 attachments into posts and blog posts.
Attachments take up valuable sever space which in turn then costs more to upgrade the space used.
It would be much easier if members used Photobucket or other photo provider when posting pictures.
Also the same for any file attachments that one would like to add would be best suited on mediafire or other provider.
I did take the time to do a how-to for Photobucket so if your not sure how to do it please see [url=h
New posts
After using the "new posts" button to see what new posts there are in this forum, how do I make them all read? I can't find a button to do so. Thanks.
