Sump plug removal
A friend of mine is helping me service the car on Saturday and I have all the filters needed. I also ordered a new sump plug and seal which is a Torx head. Does anyone know if the existing sump plug is a Torx head so we know what to look for and also is there only one under engine panel that needs removing to access the sump?
Mystery Plug
Hey All,
Just finished with the work I was doing around the boot of the car over the last day or so and seem to have this plug/filler left over and no idea where it's from!
[attachment=371]
[attachment=372]
I know this will be pretty hard but does anyone have any idea where it could be from?
H11 Filler Plug
Aware that the plug I'm referring too is the same for H11 and H7 etc. But basically I'm after a filler plug (same shape as a male plug that would provide power etc to a device, fog light H11 bulb in my instance).
What I wanna do is install my fog lights but atm I'm having issues so cannot plug the correct power cables into the female plug, so was wondering if a filler plug exists that doesn't do anything except stop dirt and water getting into the female plug socket... Hope this make
Plug behind dash
Changed my pollen filter today and noticed this plug sat there. Anyone know what its for. Mines a 2013 elite
[Image: http://i86.photobucket.com/albums/k95/st...maz0g1.jpg]
Rear Lighter/Aux Power Plug
I have the Genuine vauxhall (meriva) Rear aux power socket but it ideally requires the three pin plug as used on the tyre compressor, is anyone breaking a car that has the loom with the plug?
Just want a bit of it so i can put an aux socket in the boot.
Door Drain Plug
hi could anybody give me a link to buy a drain plug for a astra gtc as one is missing
or is it a visit to a vauxhall dealer.
Astra J Electric Plug
Hello,
Recently I decided to start taking stuff of my car and I found a random electric plug with no-where for it to go. It's found under my head lining near the interior lights. I was just wondering if anyone knew what this was??
Hello,
I have attached pict
Glow plug replacement - Things to consider
Hey Guys,
I have a 1.7 diesel 62 plate GTC.
I recently had the SVS message on the screen and had it scanned and turns out to by cylinder 3 glow plug and cylinder pressure (see pic).
I consider myself very competent DIYer but never done glow plugs before and obviously I've read the horror stories. Just wanted to know if there are any specific tips , tools , advice I should consider before tackling this job?
Any advice appreciated. Thanks in advance.[IMG]https://uploads.tapatalk-cdn.com/202106
Glow Plug Torque specs
Hey guys,
I have a 62plate 1.7 Astra GTC j.
Does anyone know what the torque specs are in Nm for the glow plugs? I've read a few things but getting conflicting results.
