Oil leak from pipe
Hi guys,
I noticed oil kind of near the bottom of the engine, lower down than the battery. I think it may be coming from a black pipe that looks like it has a large circlip and metal clip around it. I've attached a photo here and I think it could have been dripping down over time. The car is booked into my local garage tomorrow (Tuesday 17th March) but I wondered if anyone knows what this black pipe is for and should oil be coming out of it?
As always, thanks in advance.
[url=http://s1206
front flexi exhaust pipe
Has anyone had the front flexi pipe replaced on a 1.6vvti astra J by Vauxhall? if you have can you remember how much they were fitted?
Got a price from Kwik fit and they are quoting £115 fitted but just wondering how that compares to Vauxhall
URGENT HELP PLEASE - What is the pipe / oil leak
Hey guys
I have a astra J 62 1.7 diesel.
I noticed today a suction / hiss noise. Looked in my engine and saw duct tape wrapped around a pipe and could feel air escaping, this was obvs put there to try patch it and then there was oil residue over it / over my radiator fan / surrounding arwas as if it's be spraying it out.
(Will attach video links)
Video 1:The duct tape over pipe
https://youtu.be/_0Ciw7VBhrs
1) Could someone please tell me what this pipe is / does?
2) Is the oil residue and
Induction pipe for sale ??
Hi I’m looking for an induction pipe for my Astra gtc, I’ve bought an air filter but didn’t realise that the MAF sensor is attached to the air box
Jake - Replies:
Any ideas what this pipe is?
Hi guys, removed this pipe to get access to the fuel injectors but cant seem to get it back on? Makes a hissing noise when engine is running.
Engine is 1.4 Turbo (A14NET)
The pipe in question is the one in blue
Intercooler pipe
Morning all,
Drive a 2014 GTC 2,0 CDTI
Got a hole in my intercooler pipe, so just need a replacement of the rubber hose.
Found a number on eBay for the Insignia 2.0 CDTI. Is this the same pipe? If not anyone got any recomendations or part numbers for it?
Andy
Bleeding coolant liquid pipe
[attachment=1107][attachment=1106]I have just noticed a bleeding in the collant liquid pipe (not the hose but the plastic pipe) at the T-joint and tried to fix it with some glue. Things got worst, now the plastic pipe broke...see my pics attached.
Any assistance to have a minimum of replacement or even second hand spares for this part. It seems I must be looking at the plastic part fixing on the engine block and receiving all of the hoses.
Thanks for any assistance.
Kirsley
Air intake pipe location
Hi thanks for letting me join.I have a question regarding the whereabouts of the air box intake pipe,It would appear that the intake end of the pipe is in the front offside wheel arch,I can’t seem to find the opening,any ideas please? Thanks.[/b]
Intercooler pipe
Hi, I have a Astra j 1.7 cities 2013. I have oil underneath the intercooler pipe where it meets the throttle body. Should the pipe move a little where the clip is ? Or should it be tight ?
Inlet air pipe gasket part number.
Hello,
I am going to change my glow plugs and therefore need a new charge air cooler inlet air pipe gasket, how do I get a hold of one of those? I don't know how to find the part number for such things. I have a Astra J 1.3 CDTI with engine code: A13DTE
See picture
https://ibb.co/HPyxvt7
[Image:
https://ibb.co/HPyxvt7 ]
Kind regards
