Heater Panel LED Conversion
For anyone that wishes to change the colour of the SMD LED in the gear surround.
Tools required
Stubby Philips s/driver
Small flat blade s/driver
7mm socket
Fine tip soldering iron
Qty 14 805 10 x 0805 Blue LED (SMD) - Ultra Bright - UK - 1st Class Post | eBay and 1 PLCC-2 [url=http://www.e
Dbilas Flowmaster or just K&N panel filter in standard airbox?
as above...has anyone actually had a car on the rolling road to see if there is any benefit to having a Flowmaster? and to see if the standard air box is better with a K&N panel filter??
Panel next to roof lights
Anyone know what this middle panel is for next to the roof lights?
[ATTACH]448[/ATTACH]
How To: Boot Door Panel
Hey All
This is just a quick how to for removing the black trim which is inside the boot door (the bit which has the grab handles for closing the boot from the inside).
So to begin with there are 2 x 7MM bolts which hold the lid firmly in place to the frame of the boot itself, you want to remove these first. There are located within the internal grab handles (one on each side).
[color=#ff3333]Photo is of the hole where one of the bolts was removed from (will get a better photo soon). Ther
heater and blower panel
If anybody has any ideas I would be grateful. Today I have been changing over to an after market head unit. When I clipped the heater blowers panel into the new facsia , and reconnected the power to them they no longer work,no power at all. Is there a specific fuse to look for or have I some how blown the panel.
Pipercross VS K&N panel filter (Astra GTC 1.6T)
Hey guys!
Recently picked up a 2013 GTC (1.6 Turbo 180ps) and I am currently looking into smaller tuning options, at least for now anyways.
After looking at cone filters, I've pretty much ruled them out due to the limited amount of kits out there, the price of the kits available, the effort of making one myself and heatsoak issues.
So back to the question, as far as I know the Pipercross is about £15 cheaper and is a dry filter, vs the K&N which I believe is oiled.
So all I really
Speedo panel
Anyone got a speedo panel with the small display on. Doesn't need to be working as its only for soldering practice removing the display panel
Induction kit or air panel filter?
Hi, I have 2.0 CDTI GTC and I'm torn between just changing my stock air panel for the K&N air panel, the pipercross air panel or spend a little more money and replace the system with the dbilas flowmaster induction kit as this seams to look like it does the job. Would love to hear anyone's input on this as it seams like a hot topic to debate.
Has anyone got this system or managed to fit another induction kit on the 2.0 engine?
Any info or advice would be welcome
http://www.dbilas-shop.com/
Technical (electrical?) info needed for the DVD800 radio and HVAC control panel
I was wondering if anyone can provide me with the DVD800 Navi and the HVAC single zone control panel pinouts and perhaps an electrical wiring schematic.
As far as I can tell from searching online, the whole system consists of:
  • The actual DVD800 radio (part no. 13315944). I assume the only two round plugs are coax for the radio and GPS antennae but correct me if I'm wrong. What about the rest?
  • [url=ht
Info panel help please
Hi . I’m new to Vauxhall’s and am loving my Astra j. Filled the posts on here and need a helping hand please . My info panel has fallen backwards into the dash . I’ve looked here how to get at it but then panel seems a sealed unit . Any ideas how I can get it back where it should be . Ta
