Navi650 full setup
Advertised on ebay navi650 with screen, controls and Bluetooth module.
This is a navi650 full set up with head unit, control panel, screen and Bluetooth module.
13454178
13342398
95247248
13406665
All in good working order and programmed with latest vauxhall software, don't know map age though. The radio is programmed for Bluetooth Dab and reverse camera.
Screen is in good condition with very limited marks as you can see from picture.
These do need programming so please make
Navi650 Map Jumping
Hi all, has anyone else had any issues with the navigation on the Navi650. When driving along it seems to lag behind and follow the wrong roads as if it's lost GPS. It can be fine for miles but then as soon as you get into a town etc. It will completely get thrown off course. Will try a reset by taking a battery terminal off this week.
Has anyone else experienced this or similar before?
Not really a biggie for me as I don't rely on the maps, it's just a handy feature to have and would be nice
Retrofitting Navi650 from Navi600
I am retrofitting the Navi650 to my parents 63 plate J. I know on other generations of the CD units and some later stuff you could change the VIN in a 256bit eeprom, does anyone know if the applies to the Navi650/950?
I'm not sure if the VIN is in FLASH or EEprom to retrofit it.
Navi650 to 950 upgrade
Hello,
New on here. I have just bought (picking it up on Tuesday) a 15 plate Astra with the Navi 650 and looking to upgrade so i can have bluetooth and music streaming. I see a couple of posts on here that the Navi 950 can be fitted. Rusty seems to be pretty knowledgeable about this.
I understand that you need the head unit to code it, etc but is the actual changeover of the head unit as simple as removing and unplugging the 650 then plugging in the 950 then refitting all the trim, etc? Is t
Markt82 - Replies:
Navi650, mic not working
Hi, just done a navi650 swap from cd400, all good and an Intellilink navi650, however the microphone does not work, I put the mic wires directly into the pins 6 and 16 of the A11 socket, tried them both ways round and nothing, nobody can hear me via Bluetooth, any suggestions with this? Thank you
Mark
livo - Replies:
Navi650 head unit
