Mokka wiring loom
Does anybody know if the mokka share the same wiring loom throughout the whole range?!
Would like to know if it's possible to retrofit heated leather into a base model mokka
Joe
Astra Reverse Camera Kit on Mokka with Navi950
Was wondering if you guys & gals could give me some advice... would the Astra J/GTC camera kit from Vauxhall (part# 13391275) work on a Mokka with a Navi 950?
We ordered a techline with (we thought) optional extra of a reversing cam, but it was never submitted/fitted. looking at the instructions, the kit/fitments look the same.
Is this do-able and would i fall foul of Opel refusing to issue a VCI for coding it in...?
Any thoughts would be great
Kris
Mokka radio controls
I'm after a real cheap set of Mokka radio controls only want the power button and I refuse to pay £70 for a set, so if anyone sees a cheap set pop up can post a link here. Pic for reference.
[attachment=656]
The Wife's 1.7cdti Mokka
[align=center]So I bought the wife a Mokka at last.
It is 2013 EXCLUSIV 1.7cdti with AFL.
There was an issue with the AFL lights doing a constant start up which was resolved with a new headlight unit.
The Mrs wanted me to give it the full VXOCElectrabizz treatment.
So I started with an LED conversion & LED interior bulb upgrades along with adding footwell lighting.
[Image:
https://www.vxoc.org.uk/Images/rusty/Mokka/1.jpg ]
[img]https://www.vxoc.org.uk/Images/rust
Qaranc - Replies:
Mokka park assist
Picked up a mokka over the weekend, changed the Astra as there was never any room to fit the kit I had for work.
Have 2 problems the first is parking assist when I reverse, the sensor at the back and front don’t active but if I press the button on dash the fronts are activated.
Second the passenger front door doesn’t lock when the car is locked with key fob, locks manually and only works with fob occasionally does anyone know what the problem is because when I take it back I want to know i
Qaranc - Replies:
mokka sound drops
we have a mokka that when you use the phone through the radio the sound stops and i have to press the sound toggle on the steering wheel to re-activate the sound. is there a solution for this
thanks
