Vauxhall Meriva 1.8 2008 Easytronic Problem
Vauxhall Meriva 1.8 Easytronic 2008 Clutch Actuator problem
[quote]
  1. Hi Everyone,
    This is my first message on the forum, hopefully the beginning of good friendships.
    We have had the above vehicle since May 2013, it has done 55.000 miles, engine is fine, no problems, now the story begins. On 11th June, I upgraded all 4 headlight bulbs, because of limited space between battery and headlight, I removed the battery on passenger side engine bay, and changed bulbs, put battery back
New User (actually a Meriva owner)
Literally just signed up so that i could see links, So many awesome retrofits and mods.
Actually own a Meriva B SE 1.7 but no forum for that, but i know that many things are common between the Meriva B and the Astra J.
23 year old with a Meriva, just got it, but can see some potential in it.
Meriva B 1.7 A17DTS (130) Weird Starting thing
Car is the Meriva B 1.7CDTI the 130bhp model, been faultless pretty much, had a new battery a few months ago, Anyway its been coming up with the service vehicle soon message every now and again, but i gather that is for fault codes to be read? it doesn't show up all the time...
Anyway this morning i was out taking pictures somewhere, had driven there engine had been up to temperature and that before i arrived. Put the key in the Ignition had the radio on for 5 mins went to start a
Remote boot popping on a meriva (non canbus boot release i believe)
I want to make my boot open remotely when i am approaching it with bags of shopping in my hands... the car is a 2011 meriva B....
Going to try the springs on the struts, my struts are pretty weak so time for new ones, so also going to get uprated pressure struts... actually gonna get adjustable pressure struts... they start with 70 newtons of lifting power... and a bolt can be opened to release some of the nitrogen pressure if they are too powerful to close the boot lid)
This is with the
Rain sensor (meriva B)
Don't suppose anyone knows the difference between the round rain sensors, as fitted to corsa's, meriva B's, zafiras and some other vauxhalls,
They have a 2 letter code on them, SA, SB, SC and SD.
On ebay it seems the SD one is for the meriva B,  i know the SC one is for corsa's, as i got one from a corsa at the scrappers,
I've wired it in... power and earth taken from the supply to the auto dipping mirror i fitted a few weeks ago (takne from the relevent pins on the BCM as if it were fa
CD400, in meriva B, mid-speed can-bus off, wont allow can learn
Wondering if anyones had this before?
2011 meriva B (1.3 cdti) CD400 with GID,
always been getting the following code on the radio: U0074
[attachment=978]
The other 2 codes are for the IPC, as im still messing with it...
but i was getting that U0074 code when i only had an op-com for diagnosis, so it's not the clone tech2 giving a fake code, and i was getting it before i ever touched anything electrical in the car.
The Tech2 gives an option to do a can bus re-learn on most module
Auto Dim rear view Mirror (Meriva B)
Bought myself an Astra J Elite Mirror with the auto dim function, This is to fit on the Meriva B. Just doing my research so i can connect it properly to the BCM to get the signal for when its in reverse.
It came with a rain & light sensor, but from another user on here It needs to have the SD Code on it :( so might try and sell the sensor. Would like to fit auto lights and the rain sensing wiper thing.
[Image: https://www.mk3oc.com/forum/media/meriva....2116/full]
Astra/Meriva hubs for new alloys
Hello
A friend of mine has donated to me a set of mint condition 18in Vauxhall alloys. The only issue is they are off a 2013 Meriva and have 5x110 pcd.
My 2013 Astra 2.0 cdti has a pcd of 5x115.
I love the wheels and would like to use them.
Can I change out the hubs on my Astra for Meriva hubs? I figured this would be cheaper than a set of alloys.
New Member Meriva CDTI
Morning all,
[color=#383a3b]New to the owners club, but not new to Vauxhall. I’ve owned my 2011 Meriva for 18 months been getting a little bored with it recently and looking at other cars (Astra, Mokka, Insignia) but not seen anything that grabs me enough to want to trade in the Meriva.... (did see other Meriva‘s with heated seats and steering wheel that would be nice in winter, maybe there’s a retrofit guide on here somewhere).[/co
Meriva B GID problem
GID on my Meriva does not operate anymore and there is no audio on my radio. Do i have to divorce GID from donor car,or it is just plug&play? And what coult mean info on GID"Not avaliable vhile vehicle is moving"? That message is displayed all the time.
