MAF Mass Air Flow Sensor is this common problem
Hi Guys,
[b][color=black][size=medium][font=Tahoma, sans-serif]i just wanted to know ,if the MAF Mass Air Flow sensor is a common fault to go on these 2011 Astra, as my car since the I had this warning sign Diesel Partic Filter is Full Continued Driving Mandatory and then emissions control fault light  appeared on the screen. I had a service indicator illuminated even though i had the service done recently, but this
Single mass flywheel conversion for a 2010 2.0 CDTI Insignia
Hey guys!
My A20DTH160HP 2010 Insignia seems to be suffering from a worn out or damaged flywheel. It started with a small rattling noise and now, over the winter, the sound is louder than the aircon maxed out, the car vibrates at idle, it jutters whenever I shift gears or when I release the clutch pedal pulling off from a stand still. Engine braking also starts to sound like engine breaking.
Everyone seems to suspect that the flywheel is either worn out or damaged (the dampening springs
