Op-com turbo boost control learn
I have a fault code that comes up turbo boost not learned any one had this issue cheers astra j 2.0 cdti tried to learn it on op-com but don't no if I am doing it right
gazz292 - Replies:
CD400, in meriva B, mid-speed can-bus off, wont allow can learn
Wondering if anyones had this before?
2011 meriva B (1.3 cdti) CD400 with GID,
always been getting the following code on the radio: U0074
[attachment=978]
The other 2 codes are for the IPC, as im still messing with it...
but i was getting that U0074 code when i only had an op-com for diagnosis, so it's not the clone tech2 giving a fake code, and i was getting it before i ever touched anything electrical in the car.
The Tech2 gives an option to do a can bus re-learn on most module
milozic - Replies:
Headlight learn
Hi. I have a problem. I need to re-learn headlight control module (Bi-Xenon). When i try to learn it in GDS2, i get error "Device Limits Exceeded". What am I doing wrong?
[attachment=1249]
[attachment=1250]
Brake pedal sensor learn.
Is anyone in the North East that is able to do a Brake Pedal Position Sensor Relearn?
