Switcheed / Ignition positive feed required in boot area
Mr Newbie here. I am looking to install an accessory in the boot of my 2013 J - 1.6 Energy model. For this I need to locate a switched/ignition + feed.
This car does not have a rear fuse box, which make like a little more tricky.
Can anybody direct me to an appropriate feed please with a wire colour(s).
Many thanks in advance,
Ian
Ignition problem?
This is what happens when I turn the key to start the car. I hope you can here it on video http://youtu.be/jojejSidPWQ
Rapid beeps/bongs on ignition
I've just taken ownership of a 2010 2.0 CDTI Astra J Elite.  Coming from and old Type-R, I'm a bit overwhelmed by the number of electronic assists!  I've ploughed through the manual and done some googling, but I'm struggling to find out if the beeps on ignition are normal.  Basically, when turning the key to the ignition 'on' point, I get a series of bongs in rapid succession, which stop after a few seconds.  After starting the engine, the status lights all disappear (except for the expected one
ignition key
Hi there has anyone ever had a problem with the ignition key not releasing on a gtc automatic
