Howto:- Fit Vauxhall Mud flaps
[align=center][Image: https://www.vxoc.org.uk/Images/vxoc%20as...x.o.c.jpeg]
Howto:- Fit Vauxhall Mud flaps.
I'm starting at the rear.
So start by taking the wheel off the car.
[Image: https://www.vxoc.org.uk/Images/rusty/How...Rear/0.JPG]
Give the wheel liner and wheel arch a good clean (I then used panel wipe in the outer paint).
Then remove the torx screws outlined
[img]https://www.vxoc.org.uk/Images/rusty/Howto-M
Howto remove glove box & Replace Pollen Cabin filter
How to Remove and Replace the Cabin Pollen Filter
for the Astra j and GTC.
STEP ONE.....
Pull out the Door Seal just by the side of the Glove Box
to gain Access to the side Trim so it can be Removed.
[Image: http://www.vxoc.org.uk/Images/tucpal/How...ebox/1.jpg]
Just Pull the side Trim away
to Gain Access to the 4 Bolts.
[img]http:
Howto Retrofit TPMS
Howto Retrofit TPMS
Ok the first thing we need to do is check a couple of things.
Pins in the rear fuse board.
The most important one is the one at the bottom.
[Image: https://www.vxoc.org.uk/Images/rusty/How...PMS/00.jpg]
[Image: https://www.vxoc.org.uk/Images/rusty/How...PMS/01.jpg]
You will also need to check you have the following wi
