HID'S in Halogen units M.O.T.
[align=center]Thank's to Migwell030744 and Kevin for the below info.
[quote=Migwell030744]I had thought of installing a HID kit in my car as above but after tucpal's warning I looked further into it and came up with this about the subject. I am NOT now going to do the upgrade. and can't aford to swap the whole headlight system for projectors.
The latest directive from VOSA includes their view that unless strict cr
GTC HID How-to
[FONT=Verdana]I bought a 9006 5000k HID kit from Hids Direct [url=http://www.ebay.co.uk/itm/CANBUS-HID-CONVERSION-KIT-H1-H3-H7-H8-H9-H11-9005-9006-/220672732805?_trksid=p5197.m1992&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D14%26meid%3D3109239107533466727%26pid%3D100015%26prg%3D1006%26rk%3D1%26sd%3D220672732805%26][color=#0000ff]http://www.ebay.co.uk/itm/CANBUS-HID-CONVERSION-KIT-H1-H3-H7-H8-H9-H11-9005-9006-/220672732805?_trksid=p5197.m1992&_trkparms=aid
Projector HID retro fit Astra j 5 door
This How to will Cover How to fit the Mini H1 2.5 HID Projectors
into the Headlights for the Astra j 5 door
with standard Halogen Headlights
and will Give the Bi Xenon look without the Price Tag of fitting AFL
and this is also the Correct way to fit HIDs
as they Need Projectors to give the Correct Light Pattern.
PARTS NEEDED.......
[color=#F
Best HID kit links please?
So after the disaster I just had with the London colour kit. I've just pulled it all out and sent it back to them.
I'm looking at these - http://www.hids-direct.co.uk/9012-35w-sl...rsion-kit/
But just wondering if there's other better ones out there or tried and tested ones.
Also @cornishtaz I'll probably see you at the weekend mate lol if that's still ok.
Or are there bulbs
HID Error
Anyone know if theres a reason why my car just said check left and right dipped beam lights?? Ive had his installed for a week now and they've been great with no errors. Just took the car out and when auto lights came on i had the errors. Thought it was weird. But I've tried and tried again to get the error back up now and cant since I've stopped and re-started the car.
HID breakthrough or waste of money?
Hi guys
So ages ago I ordered some cheap H7 adopters with built in resistors hoping that those alongside cheap non canbus HIDS, I may avoid errors.
I already tried a set of £60 odd HIDS-Direct ones which were recommended on here but they were rubbish.
In theory, if I ran these in between eBay special HIDS, will I get errors?
[url=http://s1279.photobucket.com/user/JJ0063/media/84964C0F-86B5-445C-9B55-B9EA27AD856B_zpsjexykmfz.jpg.html][img]http://i1279.photobucket.com/albums/y527/JJ0
GTC HID conversion kit
Thought this might be a bargain for somebody, I bought a set last week and got them for 28 pounds
[Image: http://i1184.photobucket.com/albums/z331...202109.png]
HID problem
So I installed a set of HIDs this evening and was faced with this.
Kit was bought from Lush Lighting 5,000k 35w
[Video: https://youtu.be/DXiG7cmzSNU]
Anyone know why they would be doing this?
Niall
HID Conversion
I have recently purchased a 15 plate J, the only issue i am having with her is that i cannot get along with the headlights, they seem really dim, even when clean.
Possibly because I am used to running HID's in my ancient old banger .
Does anyone have any recommendations for HID conversion kits, or alternatively - bloody bright headlights?
Thanks,
Andrew
Advice needed regarding HID upgrade for a 2010 Insignia
Hello everyone!
I am the owner of a 2010 Insignia that is factory equipped with a pair of halogen headlamps. I should also mention it has headlamp washers and manual leveling.
I use this car daily mostly to and from work. During autumn / winter I finish work after night fall and my daily commute includes a 30 km piece of road through an unlit field that has been known to have the occasional jaywalking rabbit or other, larger, 4 hoofed creature.
I recently drove a friend's car equipped
