How-to disassemble airbag
[align=center]I decided to make this how-to in case someone wants to change steering wheel badge or replace it with a new one if damaged. You don't have to buy a new airbag, you just need to replace the front plastic cover. Swapped covers a month ago and it is a pretty easy job. The hardest part is to source the plastic cover.
Ok, first remove airbag. For removing airbag see here: [url=https://www.vxoc.org.uk/foru
Headlight Switch Disassemble
Morning, just wondering if someone knows how to get the headlight switch assembly apart? I'm taking it apart to change the led's in it. Not 100% how it comes apart and don't want to force/break it. Tried looking on the forum but couldn't find anything.
