Lsmcdti - Replies:
HELP astra j 1.7 cutting out
I have an astra j 60 plate 1.7 cdti, a few weeks ago it cut out and when i started it back up it would judder and cut out again, anyway aa bloke only found an egr code, it started and drove fine again so went home, i removed the egr which was not that dirty, cleaned and replaced and has been fine for approx 800 miles but on the way to work today it happened again, massive loss of power then cut off when i started it back up it cut out again, then started again and idled slighly rough but when pr
Lsmcdti - Replies:
I have an astra j 60 plate 1.7 cdti a few weeks ago it cut out and when i started it back up it would judder and cut out again, anyway aa bloke only found an egr code, it started and drove fine again so went home, i removed the egr which was not that dirty, cleaned and replaced and has been fine for approx 800 miles but on the way to work today it happened again, massive loss of power then cut off when i started it back up it cut out again, then started again and idled slighly rough but when i P
Phild82 - Replies:
CAR CUTTING OUT NEED SOME HELP
Hello all recently my car has felt like it has had the occasional misfire but tonight on way home from work it happened repeatedly losing power and almost cutting out while on the moterway there is no warning light on while driving and in cruise control it would lose power and switch cruise control off my car is a 2011 1.7cdti Astra J any help would be appreciated someone said it could be my fuel pump has anyone come across this problem as
Astra J Cutting out - no codes
I have an Astra J 2011 - 1.4 Petrol and currently have an issue with it losing power & cutting out intermittently. Have had the AA out twice to get me restarted, first time they replaced coil pack, for it only to cut out again, replaced coil pack with original and it started and ran fine to get me home. Second time they just unplugged coil pack and plugged it back in and car started immediately. Have taken the car to two different garages and neither have found any fault codes or anything logged
Roshi69 - Replies:
LED Headlights cutting out
Hi guys,
Finally got the LED headlights in yesterday.
Seemed to work fine with no errors but this morning on the way to work the dash said "check right dipped beam lamp" then the same with the left.
Not really an issue until the right one went out. Then the left one. Turned the lights off a minute then back on and they worked for a minute then the right one seems to keep going out.
Any ideas on what to check? I'll add a few pics
Could they be overheating or anything to download other the st
