Need to cut back on eBay
This is my eBay at the moment of things I've bought, doesn't include things I'm bidding on lol
Oh and the sticky pads are for pressed plates I ordered
[Image: http://s28.postimg.org/58t0cbapp/image.jpg]
car started then cut out after a few seconds
So yesterday on my run to the Port I had to relieve myself so Stopped at the services went in and used to toilet.
Came back started the car no problems at all it ran for 2-3 seconds then cut out only message to pop up was to press clutch to start.
Tried a few time and nothing every time I turned the key all the lights went out on the dash in the end I had to take the key out and then it was all ok.
Anybody any ideas or had it happen to them?
Wrong T Cut
Hey guys,
So I went and bought some t cut to work out some of the small scratches on the car and it seems to have worked well in some areas and highlighted some deeper scratches and chips in other areas (see photo)
[attachment=352]
I then realised that I'd used normal t cut when it says on the back you should use metallic t cut for metallic cars...doh! So will this do the car any damage?
