Change Steering Cruise Control Not Working
I replaced the steering wheel with a more sporty, but also in leather ...
Unlike my old steering wheel cruise control are the keys that where there is a button to activate it where previously remained pressed and activated the white light in the instrument cluster now there are two that the more there is a spy "Lim ".
Before mounting check the wiring and is the exact same same same colors wires and same positions ...
But after it is assembled and tested I realize that I will turn over the whi
Opel Astra Adaptive Cruise Control
@opelastra
Hey mate,
Your Inbox is full. Empty it and I'll reply [SMILING FACE WITH SMILING EYES]
Cruise control not working
Hi guys,
The cruise control is no longer working on my car or is temperamental intermittent problem. It used to be just an occasional thing now it has become more frequent. Basically you turn on cc, light turns white, then you try to engage cruise control it just not working anymore not turning green, tried all sorts of methods on the controls to get it to work but no avail.
I have read up it could be a number of things to cause it. It could be the actual cruise control switch on the steer
Cruise Control Problem
Just had a new box put on the car last week, now my cruise control isn't working in 5th gear. Anybody got any ideas? As far as I can see theres no gear position sensor, will engage fine in any gear and i can change up but the moment i lift foot off clutch in 5th the green light goes out.
Tried putting foot under clutch pedal and pulling up but no joy.
It's a 1.6na with the 5 speed heap of ***** box.
Just unplugged battery in the hope it may reset the ecu but I aint joyful. It wil
