Broken crankshaft bearing
Hi guys, hope you're all going good
I had a problem with my Astra's crankshaft so I would like to share with you my experience so maybe I may have some advice from you or even answer your questions if you have any.
Actually, a crankshaft bearing broke while driving on the highway which caused the engine to stop, after several attempts, the engine never started because it was blocked.
the breakage of the bearing caused damage to the crankshaft so I decided to change the crankshaft for a new one
