A16XER oil cooler
Does anyone know if the oil cooler on the 1.6 na engine is prone to leaking oil in to the cooling system. My daughter's car has oil on the surface of the water in the coolant header tank. I have drained and flushed the system twice and cleaned inside the header tank, only for the oil to return again. There isn't a great amount in there, but would like to find the cause .
The car has done 55k miles and has been well serviced and looked after. I suppose it could be the head gasket , hop
Oil Cooler 1.4T
Does anyone know what the part number is for the Oil Cooler on an Astra J 1.4T (2013) as mine has a bad leak
