Connects2 interface box constant power.
So jumped in the car this morning everything was normal got to where I was going and turned off and removed key Radio Dab & phone charger still on.
Should all turn off, so used the buttons to turn them off, same thing happened when I got home, pulled everything out and checked all the wiring everything fine.
thought about the 12v battery wire (used for storing time date etc) and the red ACC wires might want swapping over, but then on reflection it's all been fine till today.
So with that in m
Connects2 randomly not working properly.
I recently had to change the clock unit on my Astra J (as per the attached image).  Since doing so my steering controls have stopped working properly with my Sony stereo (XAV-AX3005DB).
All settings are the same, the dip switches on the interface are as they should be for a 4 line display and Sony unit (confirmed by Connects2).  The odd thing is that if I pull the power on the kit and then plug it all back in it seems to work correctly for five minutes and then suddenly the volume
